  Twyndyllyngs Live from Howard's! Chez Mosc
Digital CV/ Gate Sequencer That can Store Sequences
Page 1 of 1 [9 Posts]
OW
PostPosted: Thu Feb 28, 2013 9:47 am    Post subject: Digital CV/ Gate Sequencer That can Store Sequences Reply with quote  Mark this post and the followings unread
I am looking for a digital CV/ Gate sequencer that can store sequences allowing me to switch from one sequence to another. I already have a few analog sequencers and find it quite difficult to recreate songs, especially live.
Does anyone know of such a sequencer? Preferably DIY, but any other suggestions are welcome!
sneakthief
PostPosted: Thu Feb 28, 2013 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your question is confusing. First you talk about storing sequences then you talk about storing "patches" which usually implies a particular configuration for a synth sound.
By storing patches do you simply mean a sequence of voltages that can be played back - like a patterns sequencer where you can choose the pattern?
Or do you mean something that can store patch cable routings?
Sneak-Thief - raw electrofunk
OW
PostPosted: Thu Feb 28, 2013 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I meant storing sequences. Edited.
sneakthief
PostPosted: Thu Feb 28, 2013 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's your budget?
Off the top of my head:
http://www.doepfer.de/maq.htm
http://www.signalarts.ca/
http://www.elektron.se/products/analog?section=features
http://www.analoguesolutions.org.uk/concussor/europa.htm
http://sequentix.com/
http://www.future-retro.com/orboverview.html
If you don't mind going the modular route, you can fashion some kind of synth rack and power supply, there are more options:
Blacet Hex Zone:
http://www.blacet.com/
http://www.blacet.com/BlacetUserPage/SS2800user.pdf
Modcan Touch Sequencer:
http://www.modcan.com/EuroRack/Euro_main.html
sneakthief
PostPosted: Thu Feb 28, 2013 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, the cheapest and most powerful sequencing solution would be a Yamaha RM1x and a MIDI-CV converter, like a Kenton Pro Solo.
OW
PostPosted: Thu Feb 28, 2013 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant, thank you for the links!
So can the RM 1x be used as an external sequencer without using it's preset sounds?
sneakthief
PostPosted: Thu Feb 28, 2013 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Re. RM1x not using its internal sounds: easy - don't plug any audio into the audio outputs Wink You could also use a MIDI-CV converter with multiple outputs to control several analog synths at once.
The RM1x's grid-groove mode, midi effects and midi jobs are all outstanding. It rivals many software sequencers and is better than any iOS application, that's for sure.
The best part is that everything is stored in flash memory and never needs to be saved. You can of course import/export midi files using its floppy drive.
Just make sure the keyboard buttons are still responsive before you buy one. They can get a little crappy over time but can also be replaced.
ryktnk
PostPosted: Wed Mar 13, 2013 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
How about a nice Roland MC-4 ! ?
The original [well 2nd after MC-8] Computer controlled CV sequencer.
-ryk
roglok
PostPosted: Wed Mar 13, 2013 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
-ryk
sadly unobtainium Rolling Eyes
