meaning of Si symbol in a schematic
Page 1 of 1 [12 Posts]
new voodoo
PostPosted: Wed Oct 02, 2013 4:12 pm    Post subject: meaning of Si symbol in a schematic
Subject description: take a look at this and tell me what you guys think please?
Please take a look at this and tell me what you think (see attached)-in it there are 2 diode symbols, what I would think would nrmally mean type of clipping, but doesnt make sense here-and even if so-what does that mean if it doesnt specify a type of diode (1n5247 or 1n4148 etc)
i couldnt figure it out as there is no reference to a SPECIFIC part (no 42k resistor, or .01uf cap or 4148 diode or what-have-you).
I havent seen it befre but im far from an expert.
THANK YOU IN ADVANCE FOR ANY HELP YOU MAY BE ABLE TO PROVIDE
sincerely
SiWHAAAAT
 Filesize:  5.76 KB
 Viewed:  2338 Time(s)
Audio files: 462
PostPosted: Wed Oct 02, 2013 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Si stands for Silicium (like a 4148 diode). Other diodes that are often used in these kinds of circuits are germanium (Ge). It does work as a clipper/limiter in this ciruit.
http://phobos.000space.com/ http://www.acidtrash.com/ Stickney Synthyards
new voodoo
PostPosted: Wed Oct 02, 2013 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
yea i thought id seen that symbol before for a specific type of clipping, like bilateral r whatever.
huh. well itd be a LOT easier to understand if hed just said 4148 or whichever one he used. obviously the diodes he used didnt say "Si" on them.
He also left out the Vcc +&- for the tl0621 etc
well, Thank you
-I appreciate it. I coudlnt find it by searching, just came up with "Si Units" which are, apparently, some unit of measurement also used in schematics.
Just FYI, I left the diodes completely out of the circuit and it worked fine..so just fyi if anyone builds it.
Audio files: 167
G2 patch files: 319
PostPosted: Thu Oct 03, 2013 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not uncommon to label non-critical diodes or transistors with just Si.
In elektor schematics you'll also find DUS, TUP, TUN - where D = Diode, S = Silicon, T = Transistor, U = Universal, N = NPN, P = PNP.
BTW, not all diodes are labeled, so when you pick one from the heap it is not always clear what exactly it is - when a quick check with a meter reads 0.6V - 0.7V it must be silicon.
Audio files: 462
PostPosted: Thu Oct 03, 2013 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess silicium is dutch,.. didn't realize it was silicon in english (since we have the word siliconen in dutch too).
makes me wonder if fake boobs only conduct in one direction ?
Audio files: 167
G2 patch files: 319
PostPosted: Thu Oct 03, 2013 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Only when layered from silicon with different dopings Shocked
Audio files: 462
PostPosted: Thu Oct 03, 2013 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
ah now I get it Embarassed :
Silicon is a nonmetallic element (number 14 on the periodic table) found
in the earth’s crust. The element is a major component in semiconductors,
and its high conductivity makes it useful in solar power cells.
Silicone is a class of silicon-based chemical compounds used in paints,
adhesives, lubricants, and breast implants, among other applications.
Audio files: 167
G2 patch files: 319
PostPosted: Thu Oct 03, 2013 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, and silicium is Latin Laughing
It is funny tho, in English a lot of Latin words are used where we use Dutch words, and the other way around .. or something Rolling Eyes
analog_backlash
Audio files: 21
PostPosted: Thu Oct 03, 2013 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Having a chemistry background, I can usually work out what is meant, even if names are misused (e.g. silicone instead of silicon). I do draw the line at spelling sulphur with an f (now the official spelling):
http://www.nature.com/nchem/journal/v1/n5/full/nchem.301.html
SI units cover the whole of science and technology - not just electronics Very Happy
http://en.wikipedia.org/wiki/International_System_of_Units
Don't know if this helps anyone - I just felt like saying it...
Gary
Audio files: 284
PostPosted: Thu Oct 03, 2013 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Si, Hombre!
This is why I love this place - interesting things pop up everywhere!
Muied Lumens Base Star
Audio files: 167
G2 patch files: 319
PostPosted: Thu Oct 03, 2013 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Just now seeing this, Si si hombre, it should just work Exclamation
The idea is that it distorts a bit softer on overload with the diodes in, but you may actually like more clippy clippings.
Otoh if you'd want even softer clippings at a lower level you could put in Ge diodes.
new voodoo
PostPosted: Thu Oct 03, 2013 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanx guys, def. the more info im armed with-the more dangerous i am.
fr whatever its worth, the gargletron isnt really all that impressive, i normally throw in lm324-based lopass filters in stuff all the time-its an easy circuit that runs on 9v and is really effective..so, fr whatever its worth-i dont think this particular project is worth the relative time/effort involved for the outcome.
some one else might disagree but i tend to want MORE effective filters, not less, but then im hardly ever using for, say, vocal, or non-distrted guitars.
