CV and POTMETER use
Page 1 of 1 [4 Posts]
PostPosted: Thu Feb 11, 2016 7:49 am    Post subject: CV and POTMETER use Reply with quote  Mark this post and the followings unread
Maybe I'm kicking an open door, but this is how I use CV inputs in my synth to be.
When a connector is plugged in, the control voltage is attenuated by the potmeter and when no connector is plugged in, the potmeter is used as a control potmeter, ranging from 0 (min) to VCC (=max)
Frontpanel connectors are bought with AlieExpress
 Filesize:  19.75 KB
 Viewed:  378 Time(s)
JovianPyx
Audio files: 168
PostPosted: Thu Feb 11, 2016 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
One problem you can encounter with this circuit is that since you're plugging an output of something into this jack, you can see that as you plug it in, you are applying raw Vcc to that output for at least an instant until the jack's switch opens. That may not be very "nice" to the driving output which might be damaged.
Time flies like a banana.
corruptio optimi pessima
PostPosted: Thu Feb 11, 2016 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Good point!
Is it sufficient you think to place a resistor of about 1k in series with VCC?
The pot is 100k
Audio files: 468
PostPosted: Thu Feb 11, 2016 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah what scott said, 1K works fine.
http://phobos.000space.com/ http://www.acidtrash.com/ Stickney Synthyards
