<on air> Twyndyllyngs Live from Howard's! Chez Mosc
possible to switch between variations automatically?
Page 1 of 1 [4 Posts]
Unfed
G2 patch files: 11
PostPosted: Mon Apr 04, 2005 9:41 pm    Post subject: possible to switch between variations automatically? Reply with quote  Mark this post and the followings unread
sorry if this has been covered, maybe this falls into the same category as not being able to start/stop the master clock internally? i was playing around this evening with some variations of a drum sequencer patch, by tapping the variation buttons rhythmically with the beat - sort of a 'remix' of the variations. i was wondering if it'd be possible to somehow automate this using maybe a control sequencer sending midi CCs back to the G2 itself? sorry if i'm being vague, this may not be possible. any advice would be greatly appreciated, i think this would be an amazing feature.
Wan
G2 patch files: 46
PostPosted: Tue Apr 05, 2005 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes this is possible.
CC#70 is hardwired to control the variation. The control range has been split in 8 equal parts of 16, so a value between 0 and 15 selects var 1, between 16 and 31 var 2 etc...
There are quite some noodles and other performances in the patch archive that use this facility. It can be tricky to control the variation from a single patch itself. If the patch changes its own variation the control structure is also a target for change. So letting slot a control slot b is much easier, though not so adventurous.
Hope this helps
Grtz Wan
Unfed
G2 patch files: 11
PostPosted: Tue Apr 05, 2005 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you Wan, i hadn't loaded many user performances so far. i should be able to find some good examples of how others have used this before. very glad that this doesn't need to be done from an external sequencer.
PostPosted: Tue Apr 05, 2005 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mother Misty is a big fan of this, check those drum performances for examples!
