 Forum index » Clavia Nord Modular » G2 Performances - Completed
PERCUMM
Page 1 of 1 [9 Posts]
mother misty
G2 patch files: 130
PostPosted: Tue Mar 29, 2005 4:51 am    Post subject: PERCUMM Reply with quote  Mark this post and the followings unread
Experimental drums/percussion performance with lots of glitchy efx's.
I don't think this will work on unexpanded G2's
as usual, change variations in slot D.
(first 7 variations are filled)
have fun!
PERCUMM-AE1.mp3
Audio example PERCUMM
 Filename:  PERCUMM-AE1.mp3
 Filesize:  1.1 MB
 Downloaded:  402 Time(s)
PERCUMM-AE2.mp3
Audio Example 2 PERCUMM
 Filename:  PERCUMM-AE2.mp3
 Filesize:  1.17 MB
 Downloaded:  415 Time(s)
Percumm.prf2
Experimental Drums/Percussion performance with lots of glitchy efx's
 Filename:  Percumm.prf2
 Filesize:  26.8 KB
 Downloaded:  882 Time(s)
Roland Kuit
G2 patch files: 124
PostPosted: Tue Mar 29, 2005 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Misty, a bjoettie, as usual Cool Cool Cool
Roland Kuit
http://rolandkuit.com/
Acidfever
PostPosted: Tue Mar 29, 2005 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
If this will not work on unexpanded G2, what can be done to get it working? Can it be split in some way? Or maybe a lite version of the performance?
Audio files: 107
PostPosted: Tue Mar 29, 2005 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, Mother. I like this a lot. Great to play with the variation buttons as a real-time controller. In this case variation 8 is fabulous because it drops in a rest. Superb... Cool
General Elektrick
PostPosted: Tue Mar 29, 2005 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
bounce bounce compress compress bounce bounce
compress compress shakng2 shakng2 compress compress
bounce bounce shakng2 shakng2 bounce bounce
compress compress bounce bounce compress compressbounce bounce compress compress bounce bounce
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
mother misty
G2 patch files: 130
PostPosted: Wed Mar 30, 2005 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess I could try to make a light version, but it won't be that easy Sad
I'll see what I can do... Pitty there isn't a tool where you can see if it will work on unexpanded G2's or not...
PostPosted: Wed Mar 30, 2005 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I have an unexpanded G2...I disabled Slot A I think, to hear slot B, etc.
I know it's obvious, but I'll just throw it out there for newbies anyway... if the VA + FX of all slots in a performance is greater than 400%, it won't run on an unexpanded G2. Of course, if you load a performance too large for an unexp G2, it will load what it can, and the rest of the slots will have "--" in the % use .
These patches are inspiring me to get the expansion card, however Smile
mother misty
G2 patch files: 130
PostPosted: Fri Apr 01, 2005 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
A "light" version of PERCUMM.prf2
(The sum of the patchload of all slots is now 399,2 so this should work on an unexpanded G2)
I've deleted the recycle delay in slot C and some other things, also some variations are changed
Sounds less glitchy as the original, but at least you get an idea of how the "big brother" sounds Smile
Percumm LE.prf2
PERCUMM LE - 'light' version of PERCUMM.PRF2
(should work on unexpanded G2's)
 Filename:  Percumm LE.prf2
 Filesize:  24.79 KB
 Downloaded:  791 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Tue Apr 05, 2005 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
nope, it doesn't work here Sad
Thanks for the effort though.
