cappy2112
Joined: Dec 24, 2004 Posts: 2088 Location: San Jose, California
Posted: Fri May 27, 2005 10:34 pm Post subject:
Micro modular friendly patches |
Does anyone out there still have a Micro ?
Was there every any naming convention used to indicate patches that would work for the MM ?
Are there any tools available that can scan through a directory of patches to determine if they will play on a MM ? |
Joined: Apr 03, 2004 Posts: 19593 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat May 28, 2005 3:06 am Post subject:
Re: Micro modular friendly patches |
| cappy2112 wrote: |
Was there every any naming convention used to indicate patches that would work for the MM ? |
Nope, but some people did make patches with the micro in mind, there should be lots of 'm actually.
| Quote: |
Nope, but it wouldn't be too hard to make such a tool, see http://www.iaf.nl/Users/BlueHell/info/patch303.htm#[Header]
Jan. |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sat May 28, 2005 9:42 am Post subject:
I never had one of these, but I might pick one up. They are fabulous... _________________ --Howard
my music and other stuff |
cappy2112
Posted: Sat May 28, 2005 8:28 pm Post subject:
| Blue Hell wrote: | | cappy2112 wrote: |
| Quote: |
Jan. |
Thanks for the patch format spec. |
Wout Blommers
Joined: Sep 07, 2003 Posts: 4509 Location: The Hague - The Netherlands
Audio files: 123
G2 patch files: 12
Audio files: 116
G2 patch files: 317
Posted: Sun May 29, 2005 1:17 pm Post subject:
| Wout Blommers wrote: |
Sorting out Micro Patches can be done the best searching on number of Voices. (1) At least, that's what I think... |
That's what I meant to say, thanks for making it explicit :-)
Jan. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun May 29, 2005 2:01 pm Post subject:
Yep, BUT if someone made a Patch special to the Micro and he was able to keep it below 50%, 2 Voices were possible, wasn't it? I thought the question was special asking for those Patches... That's why I gave these URL's of Patchers surely working with a Micro.
Wout
(who isn't that sure, anymore) |
Audio files: 116
G2 patch files: 317
Posted: Sun May 29, 2005 5:27 pm Post subject:
Hmm yes indeed there were some polyphony freaks at work on micro's ... 6 or 7 voice patches even ... ok so it's a bit more complicated to auto find such patches, thank god we have Wout :-)
Jan. |
cappy2112
Posted: Sun May 29, 2005 7:11 pm Post subject:
I"m glad you're still around Wout. You've got a great memory for all things Nord! |
cappy2112
Posted: Sun May 29, 2005 7:13 pm Post subject:
| Blue Hell wrote: | | Wout Blommers wrote: |
Jan. |
Doesn't the MM have 1 DSP- which is capable of four notes- max ?
I wrote my program to search for 4 notes or less.
Ok- in reality 4 notes with very minimal patch load, probably isn't very useful, but ... |
davep
Joined: Jul 05, 2004 Posts: 465 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Sun May 29, 2005 11:15 pm Post subject:
Remember Terryfunken's low-DSP pad patches called "8bitOrchestra"? I made a few modified versions as well. These used three LFOs as detuned audio oscs, and varied from about 19% DSP down to less that 10% DSP. _________________ Dave Peck |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon May 30, 2005 1:54 am Post subject:
There was some competition in creating Voices on the Micro.
I think I found two of these.
I have no Micro anymore (only full Classics), so I can't check if it's alright.
Wout
 Download |
| Filename: |
28VoiceOnMicro.pch |
821 Bytes |
| Downloaded: |
93 Time(s) |
 Download |
| Filename: |
32VoiceOnMicro.pch |
915 Bytes |
| Downloaded: |
108 Time(s) |
Audio files: 116
G2 patch files: 317
Posted: Mon May 30, 2005 2:54 am Post subject:
That was one of the things keeping the NM list alive, all this experimenting with minimal suff - we don't do that anymore for the G2 (probablt it's too big for that ?)
Jan. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon May 30, 2005 3:51 am Post subject:
Pushing the boundaries, Jan. That is one of the things people love the best.
How many oscillators can you use in the NM Classic?
The G2 is much more a players instrument, although, people are saying that! The NM Classic was more an experimental machine, both to the users as for Clavia itself. I still believe something of the designer's thoughts are really in the object itself...
Wout
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Doornekamp_Ico/Iclock02.pch
transforms your Micro into an almost real Schwarzwalder Coo-coo-clock, which tics and coo-coo's on the hour. In the Editor one can read the exact time... |
cappy2112
Posted: Mon May 30, 2005 1:32 pm Post subject:
| Wout Blommers wrote: | Pushing the boundaries, Jan. That is one of the things people love the best.
Wout
thanks again- |
Johan Zwart
Joined: Mar 26, 2004 Posts: 448 Location: Utrecht, Netherlands
cappy2112
Posted: Mon May 30, 2005 11:02 pm Post subject:
Nothing in particular at the moment- I've got an MM on the way, and wanted to get some sounds for it so I can check it out- as well as uunderstand what restrictions the MM has for patches
thanks to al who replied to the MM query! |
hyperstationjr
Joined: Jun 12, 2005 Posts: 88 Location: New Jersey/New York
G2 patch files: 24
Posted: Sun Jun 12, 2005 9:40 am Post subject:
I had a Micro for about 2 years till I upgraded to a G1 key and added a G2 Engine. I had a HUGE selection of Micro patches I made, with patches up to 16 note poly (still sounded good too!), as well as a ton of downloaded patches I optimized for the Micro.
However their on a HD on my Win-98 machine with a dead motherboard, and no PC's in site aside from a laptop.. if anyone could give me a fix to this situation I'd gladly hook you up... _________________ Studio:
Akai MPC2000xl.
Behringer BCR2000.
Clavia Nord Modular G1 Key* (considering to sell/trade)
Clavia Nord Modular G2 Engine.
Roland Alpha Juno1.
Yamaha QY70.
Want to sell/trade
Ensoniq ESQ1
Korg MS2000
Kurzweil K2000r V3
Yamaha TX802 |
cappy2112
Posted: Sun Jun 12, 2005 10:53 am Post subject:
| hyperstationjr wrote: | I had a Micro for about 2 years till I upgraded to a G1 key and added a G2 Engine. I had a HUGE selection of Micro patches I made, with patches up to 16 note poly (still sounded good too!), as well as a ton of downloaded patches I optimized for the Micro.
However their on a HD on my Win-98 machine with a dead motherboard, and no PC's in site aside from a laptop.. if anyone could give me a fix to this situation I'd gladly hook you up... |
You can always just connect the drive as a slave to another PC- like a computer at work, then copy your files off. |
hyperstationjr
G2 patch files: 24
Posted: Sun Jun 12, 2005 12:53 pm Post subject:
I would have but I don't have access to a PC tower anymore, hence my problem. _________________ Studio:
Akai MPC2000xl.
Behringer BCR2000.
Roland Alpha Juno1.
Yamaha QY70.
Want to sell/trade
Ensoniq ESQ1
Korg MS2000
Kurzweil K2000r V3
Yamaha TX802 |
