9V Sample and hold
Page 1 of 1 [4 Posts]
mitch
PostPosted: Sun Aug 28, 2005 4:25 pm    Post subject: 9V Sample and hold Reply with quote  Mark this post and the followings unread
I've been working on making a sample and hold circuit that will run on +9V. Here's a preliminary design.
This is not quite working yet. Sugestions greatly appreciated.
Audio files: 167
G2 patch files: 319
PostPosted: Sun Aug 28, 2005 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcom to EM mitch.
I'm sory, but I had to delete your double posting. this one seemed most approriate to keep.
Here is some text that was in the other post but not in this one :
This is not quite working yet. The LFO works and the noise source is working well. But the sample and hold section is quite working. If anyone has any suggestions or can point any glaring mistakes feel free, it will not hurt my feelings.
dnny
PostPosted: Mon Aug 29, 2005 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i don´t know if this helps at all. but take a look at these sample and holds. there is good description how the circuits work -
so maybe youy will figure out whats wrong
S&H 2
Single Chip Simple Sample and Hold
daniel
www.koelse.org
flickr: cable porn group
mitch
PostPosted: Mon Aug 29, 2005 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I had seen these before but I felt there were too many parts and they include many extra features that do not need. These also run on a bipolar power supply.
Taking a second I look I might be able to borrow a few ideas.
If understand the how this works. It seems the important ideas are that the LFO needs to have high fast peak. The gate of the sample FET (Q1 in the case of the Single Chip Sample and Hold) needs to be at 0V when the LFO is low. The CV buffer (U1-b in the Single Chip Sample and Hold) must have insanely high input impedance, hence the use of TL-084 JFET op-amp.
