Spectral Xfade - More like a real Wavetable
Page 1 of 1 [4 Posts]
TheRain
G2 patch files: 9
PostPosted: Mon Jan 02, 2006 3:49 pm    Post subject: Spectral Xfade - More like a real Wavetable Reply with quote  Mark this post and the followings unread
This patch takes up significantly more resources than the PM Xfade patch, but it sounds a lot cooler IMO. It is quite similar to the PM Xfade since I mostly just dropped in different OSCs and changed a few routings. I did tweak some of the modulation path because in the PM xfade some levels and poles were not defined correctly. Also there are 8 variations with a named catalog in the patch itself.
Spectral XFade1.pch2
Wavetable-like synthesis using Spectral Oscilators and FM to make up different waveforms.
 Filename:  Spectral XFade1.pch2
 Filesize:  4.96 KB
 Downloaded:  801 Time(s)
Audio files: 167
G2 patch files: 319
PostPosted: Mon Jan 02, 2006 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've deleted the duplicate posting.
Audio files: 130
PostPosted: Mon Jan 02, 2006 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice patch. I like the 8 complete variations. This is a nice rich sound.
TheRain
G2 patch files: 9
PostPosted: Tue Jan 03, 2006 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about that double post... didn't realize I did that.
Thanks Howard.. glad you enjoyed it. Yah, well you know I just got my G2 and just started posting here a few days ago and it occured to me that a lot of people won't really dig into the inner workings of what I post here.... of course unless it is as enlightening as something Rob has done or some of the other "bulding blocks" people... so I figured I should make a full set of variations from now on. If I'm gonna spam this board with my creations, at least I could do that Wink I should note that I went through every wavetable synthesis thread on the G2 section of this board before I designed this.
Cheerio,
Collin
