cds56
Posted: Thu Nov 08, 2012 7:21 pm Post subject:
Another completed SoundLab! (pics included) Subject description: Finally furnished my minisynth!! |
I started building my minisynth in December 2010(I believe). I populated the PCB, and... well wait one second.
Ray in the kit you sent me you left out ONE cap! a single ceramic cap of a common value which I had, but still. that's a single issue with it.
So I got busy around that time so let's say around 9 months later I cut a crude faceplate from a new aluminum cookie sheet, drill it out, and wire the whole thing based on Ray's schems and faceplate layouts (so easy)
I measured and cut out the box but never assembled it. It was left housed in an old shoebox.
until last weeekend where I did it all in a 36 hour time period !!
Note: as of late, the noise generator has become plagued with immense oscillator 2 bleedthrough and noise that doesn't sound anything like noise!
TL; DR I took two years to do a two week or less project because lazy. am satisfied !
imgur: http://misteralien.imgur.com/all/ |
Posted: Thu Nov 08, 2012 11:44 pm Post subject:
I had a lot of trouble with bleed into the noise; I used the "optional improvements" noise circuit and it went away.
My build's not done yet though
Edit: PS your images are not publicly accessiable  |
ashleym
cds56
Posted: Fri Nov 09, 2012 1:22 pm Post subject:
Whoops, I couldnt figure out how to link directly to the album which was public, okay everything is viewable now I hope...
here:
http://imgur.com/a/K3v85
The faceplate needs trimming, and I should takea look at the optional improvement noise circuit... |
Posted: Fri Nov 09, 2012 9:26 pm Post subject:
| Yep, was able to see it now. Thanks! |
cds56
Posted: Sat Nov 17, 2012 12:44 pm Post subject:
help |
well apart from the noise gen, I found a little quirk..
When I tap the solder joint for a resistor on the right-top side of the pcb with my finger, it triggers a gate.
What does this mean? my finger is not shorting out any of the other connections..
http://www.youtube.com/watch?v=5ScqhTyZ1i0 |
Joined: Apr 03, 2004 Posts: 19598 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Nov 17, 2012 1:03 pm Post subject:
Re: help |
| cds56 wrote: | | What does this mean? |
It probably means that you found a high impedance point there that you are injecting some hum into. _________________ Jan |
cds56
Posted: Sat Nov 17, 2012 1:05 pm Post subject:
would the answer to that be "Stop touching your PCB while the synth is turned on"?
I guess that could make.. sense.. |
Audio files: 116
G2 patch files: 317
Posted: Sat Nov 17, 2012 2:21 pm Post subject:
Or don't stop - it won't kill anything likely  _________________ Jan |
bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
Posted: Fri Nov 23, 2012 2:15 am Post subject:
Re: help |
| cds56 wrote: | When I tap the solder joint for a resistor on the right-top side of the pcb with my finger, it triggers a gate.
It means you have "trigger finger"
a common ailment amongst synth enthusiasts.
and what blue said. _________________ _Richard_  |
cds56
Posted: Wed Dec 05, 2012 6:22 pm Post subject:
Trigger finger! XD that's rather punny...
but I like it, guess I'll keep touching my synth in out of reach places  |
