 Forum index » Instruments and Equipment » MAX/MSP - Pd
cross modulation
Page 1 of 1 [2 Posts]
mi_dach
PostPosted: Tue Mar 07, 2006 2:19 am    Post subject: cross modulation
Subject description: not working...
Hi, I have tried cross modulation as described by mosc in this thread (scroll down a bit), and unfortunately it's not working.
I used two cycle~ objects, and it works fine until I make the last connection (from a cycle~ output to the frequency input on the other cycle~ ). At this point, all sound disappears.
Is it possible that max/msp is not allowing this kind of circular connection? can someone please post a patch with a working cross-modulation in it, I'd be very grateful!
thanks
Ivity
G2 patch files: 57
PostPosted: Tue Mar 07, 2006 7:18 am    Post subject: Re: cross modulation
The output amplitude of the cycle~ is between -1 to 1 and you try to modulate the frequency of another cycle~ object (carrier) with this kind of signal. So, in this case, the output frequency of the second cycle~ object (carrier) is between -1 to 1 Hz (ultra low frequency) and that's why the sound disappeared. Try to multiply the output of the modulator (the first cycle~ object) with *~ object to reach the audible frequencies, before you connect it to carrier frequency input.
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
Niio1
