caveman I.C.s!
Page 1 of 1 [8 Posts]
toppobrillo
PostPosted: Mon Mar 20, 2006 3:13 am    Post subject: caveman I.C.s! Reply with quote  Mark this post and the followings unread
the following was cutted and pasted from the other thread....
~also, i have decided to make two 3-LDR/1-LED, [a la 'hairball']
controls to at least test my idea of the 'spread' control dynamic of the synbal circuit. which i think [i hope] will be interesting enough to do. my plan is to inversely shift the frequency of the 3 highest and lowest oscillators... a la 'hairball crossfade circuit' with control voltage.
when the top 3 are getting higher, the bottom 3 are going lower, and vice-versa. also, the topmost osc will be affected more than the one below it, and so on... same for the bottom 3, where the lowest in freq. will be affected more than the others. this would be alot easier to diagram than write about!
i think it will definitely be good to have at least 4 different tap-points of this configuration brought out to a mixing section, maybe a matrix style mixer? or a joystick... hmm.. maybe thru simple bandpass filters. wow this just got alot bigger of a thing... sorry to ramble on as much about an entirely different project, ill keep y'all posted~
as promised, im keeping you posted. i couldn't resist... it's 5 AM im going to bed but i just finished 2 caveman vactrols, and here are pictures taken by a shitty camera. enjoy!
 Filesize:  27.22 KB
 Viewed:  2877 Time(s)
 Filesize:  21.96 KB
 Viewed:  2878 Time(s)
 Filesize:  20.64 KB
 Viewed:  2876 Time(s)
Audio files: 51
PostPosted: Tue Mar 21, 2006 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
I love the look o' dem chips!
Guitarists have known for ages that a beautiful instrument looks as cool as it sounds. You're (in fact we are all) doing the same for the electronic music world!! Cool
We would lose our friends.
So,.........
PostPosted: Tue Mar 21, 2006 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Great looking DIY Vactrols!! What did you use as the coating?
(It's just that it looks like that 'sticks like s**t' stuff (no more nails) you can get from DIY shops. If it isn't, I apologise- but if it is, are you using the solvent-based version or the water-based one? (the latter is better imo- because it isn't poisonous!!))
ACHTUNG!
mi_dach
PostPosted: Tue Mar 21, 2006 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha!
these things are absolutely awesome, thanks, you've made my day Smile
toppobrillo
PostPosted: Tue Mar 21, 2006 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey thanks guys! the coating i used is an air-dry modeling clay, i used the inside of a thimble as a kind of mold. i am making more of these in the vtl5c2/3 configuration too soon.
josh
Scott Stites
Audio files: 96
PostPosted: Tue Mar 21, 2006 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa, extremely kewl opto-couplers there!!! Me like Very Happy
A friend of mine did this a while back. He measured the components out carefully, put them together and......didn't work. Didn't work quite badly, actually.
He finally figured out the potting compound he used was conductive
Ouch!!!
Cheerio,
Scott (finally going home tomorrow)
Audio files: 51
PostPosted: Wed Mar 22, 2006 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I got 8 LDRs today and plan on building some mutant "vactrols". They have a dark resistance of over 1M and an "under a lamp" resistance of about 3K. Does this sound good? What is the schematic for the filter you're working on Scott? What is the vtl5c2/3 configuration?
So,.........
Scott Stites
Audio files: 96
PostPosted: Wed Mar 22, 2006 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Uncle K,
Mutant Vactrol Filter schemos can be found here:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id17.html
I think your optocouplers will work fine - perhaps a little darker sounding (I think the min resistance of the VTL5C3/2's I used go a bit lower in resistance). You can always try swinging the cap value a little lower to brighten it up if you need.
Take care,
Scott
