resistor tolerence question
Page 1 of 1 [2 Posts]
shermer
PostPosted: Fri Mar 24, 2006 12:50 pm    Post subject: resistor tolerence question Reply with quote  Mark this post and the followings unread
hi
im about to start building the soundlab and in the parts list some resistors require a 5 percent tolerence. is it ok to use ceramic resistors here? they are all i can find with that tolerence. can't find any metal type ones.
thanks
PostPosted: Fri Mar 24, 2006 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a Multi-meter that you can use to measure the actual resistance?
The % (1%, 5%, or 10%) just means how accurate the production of those parts was. Your aim is still to get the appropriate value. So just measure what you have, and if it's within 5%, it should be fine to use, regardless of what tolerance it is marked as.
