Capacitor question
Page 1 of 1 [3 Posts]
microscope
PostPosted: Tue Mar 28, 2006 12:18 pm    Post subject: Capacitor question
Subject description: 2u2 NP
Here’s my latest stupid question. I assume C10 on Andrew Sharp’s components list is supposed to be “2uf NP” instead of “2u2 NP.” If “2u2 NP” is correct I don’t know what that is. I have 1uf NPs. Is it possible to use those instead? I found on Google that I can use 2 1uf NPs “in series but with like polarities connected together.” What would this look like on the stripboard layout?
I should be finished with it soon (one way or another) so my stupid questions will end.
Thanks,
Kevin
PostPosted: Tue Mar 28, 2006 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
2u2 is a compact way of saying "2.2 uF". In the original schematic, C10 is .1uF. Either way, it doesn't matter much, it['s just there to stabilize a reference voltage, created by two resistors (R75 & R73). I saw the strip board layout page, and it says all the designators are the same as the original schematic, but I didn't find the component list you spoke of.
So, you can probably use just the one 1uF you have, or use a .1uF if you've got it. I don't think the value is extremely important.
fluxmonkey
PostPosted: Wed Mar 29, 2006 9:43 am    Post subject: Re: Capacitor question
Thanks,
Kevin
outside the US, its pretty common write parts values by putting the units where the decimal point goes... so 2n2 is a 2.2n cap; 4u7 is a 4.7uf, etc. decimal points can often get lost. Caps can also be "NP", which means "non-polarized"--electrolitic caps are usually polarized, but you can get some that aren't.
b
