robot voice
Page 1 of 1 [5 Posts]
dnny
PostPosted: Mon Apr 03, 2006 10:03 pm    Post subject: robot voice
Subject description: voice changer PCB + sound sample
i had this post in wrong place so i have now moved it here:
there is also little "vocoding" or "robot voice" module that uses two CD4007 chips.
...alterates the introduced speech so that it sounds like the voice of a robot. Adjustable effects. The device should be connected between the microphone and amplifier (or tape recorder).
here is a non informative pdf
and here comes the parts list:
T transistor BC547
IC1,IC2 MOS-IC´s 4007
C1,C3,C4,C5 elcas 0,47uF 50V
C2 elca 47uF 16V
C6 capacitor 150nF
C7 elca 100uF 16V
R1 15K
R2 1M
R3 2k4
R4 2M7
R5 1k1
P1 potentiometer 10k
P2 potentiometer 47k
and the PCB + component layout
if you want something else. try the Vocaphonie, you can find it here
sound samples soon
dnny
www.koelse.org
flickr: cable porn group
dnny
PostPosted: Tue Apr 04, 2006 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
and here is a short sample of robot voice.
i think it needs to moded or bended to get more results - but it´s nice if you don´t expect it to be a complete vocoding unit
d
robotvoice.mp3
 Filename:  robotvoice.mp3
 Filesize:  228.7 KB
 Downloaded:  2454 Time(s)
www.koelse.org
Hank Reynolds 3rd
PostPosted: Tue Apr 04, 2006 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds pretty cool !!
looks like its something that could be built upon...sounds quite granulary too...
dnny
PostPosted: Tue Apr 04, 2006 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
something like this:
the pollution box (bended from megaphone type voice changer toy)
www.koelse.org
zipzap
PostPosted: Wed Apr 05, 2006 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice sound. I´m wondering, if you ommit the in/output cabs, what would this do to a controll voltage?
