LFO question
Page 1 of 1 [9 Posts]
neo644
PostPosted: Mon May 01, 2006 9:01 pm    Post subject: LFO question Reply with quote  Mark this post and the followings unread
hey, looking at this panel layout:
http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/faceplates/DanGraySoundlabface2u.pdf
in the LFO the switches have this labels:
- Square | Angular
- Ramp | Tri | Saw
compared to the original layout:
http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/showbigpicture.php?PICNUM=2
which has:
- Ramps | Rect
- Ramp | Tri | Saw
Ramps == Square & Rect == Angular?
and then: could somebody show me which one is which? i'm kinda mixed up here. i would really apreciate if somebody could show me some graphs.
thanks alot!
ladislaobiro
PostPosted: Tue May 02, 2006 6:39 am    Post subject: Re: LFO question Reply with quote  Mark this post and the followings unread
It should be something like shown in the picture...
I hope this helps...
ladislao
 Filesize:  17.66 KB
 Viewed:  3245 Time(s)
neo644
PostPosted: Tue May 02, 2006 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
hey thanks alot!
just to be shure that i have it okey, would it be like this:
Square == Square
Angular == Rectangular
Ramp == Ramp
Tri == Triangular
Saw == Sine
and i assume the difference between the square and the rectangular si that the rectangular is pwm?
ladislaobiro
PostPosted: Tue May 02, 2006 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
neo644 wrote:
1) Square == Square
2) Angular == Rectangular
3) Ramp == Ramp
4) Tri == Triangular
5) Saw == Sine
I would say:
1) yes.
2) yes, but I'm not sure...
3) yes.
4) yes.
5) no. I would say that a "saw waveform" is ramp or a triangular wave, but I don't know which one is the correct one... and maybe there is another option: a ramp waveform can be shaped in two different ways (see the picture), so it is possible that one is called "ramp" and the other is called "saw"... but I think I'm gving more confusion than help...
anyone else to clear it out?
yes, I think so...
that was my very best... Surprised
ladislao
 Filesize:  7.01 KB
 Viewed:  3235 Time(s)
opg
PostPosted: Tue May 02, 2006 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I think ramp and sawtooth are interchangeable. You have to specify, therefore, if the waveform is a downward or reverse or upward or topwise or whatever definition. I just got a Casio CZ-1000 last week, and I should know the answer to this. The vibrato has 4 waveform choices: the triangle, two ramps, and a square. I just can't remember what they refer to them as. Embarassed
And then, there's "pulse" and "square." Are they interchangeable?
Update: Here is a diagram from a MAX/MSP site:
http://www.creativesynth.com/MAXMSP/001-SynthBuildingMSP/images/img_06_waves.gif
neo644
PostPosted: Tue May 02, 2006 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
so, here we have it, my LFO switches layout.
i was thinking, how would i use the square/rectangular ? because the other switch doesn't have an "off" position. does this switch, the square/rect overides the other one?
LFO switches layout
 Filesize:  4.68 KB
 Viewed:  3224 Time(s)
Pehr
PostPosted: Tue May 02, 2006 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Isn't it: angular == ramp/saw/tri?
So Its either the square or one of the ramp/saw/tri-waveforms.
At least thats how mine works... But the angular-switch must be set to tri to have the square going...
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Pehr
PostPosted: Tue May 02, 2006 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
"angular" must come from "angle", which supports my theory "angular == ramp/saw/tri"
YouTube channel
flickr photostream
neo644
PostPosted: Tue May 02, 2006 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, that totally makes sense.
plus, if your sound lab works like that, then there no argument jeje
i'll have to change the layout then
