 Forum index » Instruments and Equipment » Cubase
MC909+ Cubase Midi Multitrack recording
Page 1 of 1 [5 Posts]
Dexter76
PostPosted: Thu May 25, 2006 7:45 am    Post subject: MC909+ Cubase Midi Multitrack recording Reply with quote  Mark this post and the followings unread
Greetings,
i'm looking for a way to record the 16 parts of my MC 909 into 16 separate tracks in CUBASE 3 SX.
The groovebox is master and midi out to my sound card (midi in port)
I open a multitrack session in cubase (16midi tracks) but i don't know how to assign the track 1 in cubase to track 1 of my Groovebox, track 2 to track 2...etc..so that the 16 tracks can be recorded separately and simultaneously when they play.
Any suggestion?
Thank you in advance
Rgds
DX76
paul e.
PostPosted: Thu May 25, 2006 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
each 'track' in mc909 should correspond to a midi channel
track 5 = midi channel 5
Spiral Recordings
Dexter76
PostPosted: Thu May 25, 2006 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
I've installed a patch (script) that let Cubase recognize my MC909 as output device. The problems are from MC909 to Cubase.
When i play a part on my MC909, for example part 1 and i want to record it just on the track 1 on cubase, it's recorded on all the tracks.
In other terms i cannot split and assign the 16 channels that comes from my 909 to cubase.
Dexter76
PostPosted: Sat May 27, 2006 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
No one can help me out?
Regards
DX76
make
PostPosted: Mon Aug 28, 2006 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
So you are trying to record 16 midi channels from your groove box?
Are the individual channels set up correctly from the MC909? IE: each instrument is set to its own midi channel?
If all the data is being recorded in but not separated then it might be a couple of things:
*you haven't armed all the 16 channels to record at once or they are not set correctly what channel to listen to.
*the cubase channel is recording all the data on one channel but then you can separate it using a function called "dissolving midi". You can then split the midi in various ways: by midi channel or by pitch
Niio1
