<on air> Currently on the open port PHOBoS - M.I. Cloudius
  Muied Lumens Frequencies
Simple LED flasher circuit for vactrol pitch LFO?
Page 1 of 1 [8 Posts]
gmeredith
PostPosted: Wed Jun 28, 2006 5:25 pm    Post subject: Simple LED flasher circuit for vactrol pitch LFO? Reply with quote  Mark this post and the followings unread
I'm a newbie looking to add a pitch vibrato to my bent Casio SK1 via a vactrol resistor. I need a simple LED flasher circuit that can flash from 1 flash/second up to about 20/second. All the 555 circuits i've seen only seem to flash slow (up to 2/second). Does any one know of one?
Thanks for your help, great forum
Cheers, Graham
Scott Stites
Audio files: 96
PostPosted: Wed Jun 28, 2006 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Graham,
You should be able to get a cap value on a 555 circuit to get a faster flash rate on a 555 (in this case, if you're running off of battery, I'd suggest a 7555, which has a mere fraction of the current draw a 555 has).
If that doesn't do the trick, a simple op amp LFO driving the LED might work, but I suck at single supply circuits - the Uncle K-man might have some good suggestions. Plus he might have a better grip on any coriolis related issues for down under Very Happy
Cheerio,
Scott
gmeredith
PostPosted: Wed Jun 28, 2006 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I am running it off batteries - the Casio runs off 5 "AA" batteries (7.5V total), so current draw is an important factor here - I'll check out the 7555. Is it a direct replacement for the 555, or does it have different pin-outs?
Thanks for the great advice Very Happy
Cheers, Graham
dnny
PostPosted: Thu Jun 29, 2006 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Graham welcome to electro-music.com forum
have you tried 555 timer lite?. freeware that calculates the component values for desired timers using 555 and 556.
here is example whit 6volts (use only 4 AA batteries) and 20Hz (20times/second)
you can tweak the values until you get what you wanted.
should this topic be moved to our circuit bending sub-forum ?
opinions?
daniel
www.koelse.org
flickr: cable porn group
Mikmo
PostPosted: Thu Jun 29, 2006 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Go to my website here:
http://www.mikmo.dk/cblfo.html
There's a 555 based LFO, compleate with VERO board and real PCB layout.
To get the timing you want just experiment with the potentiometer value and the timing capacitor.
Stay Cool
Mikael
http://www.mikmo.dk
gmeredith
PostPosted: Thu Jun 29, 2006 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks heaps, guys - looks like the thing I'm after! Thanks Daniel for the link and also the example 20hz - that will get me off to a good start. Thanks Mikmo for your circuit, I think I'll go with it!
Cheers and thanks, Graham
Scott Stites
Audio files: 96
PostPosted: Fri Jun 30, 2006 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget to try a 7555 in there - I've become quite a believer in them. If you're using a battery, the 7555 will not suck it dry. They're also much, much better about not putting garbage on the supply lines. It's pin for pin to a regular 555.
Scott
gmeredith
PostPosted: Sun Jul 02, 2006 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Scott,
Just finished building the circuit, I got a 7555 as you suggested, it's working really great!!
Just for those wanting a similar thing to me, if you look at the screenshot that Daniel kindly provided above, he showed an example 555 circuit with some values for R1, R2 and C1, to give an oscillation value of 20Hz.
I used the program to fiddle some more values, and came up with:
For a LFO range of 0.3 - 30Hz (an ideal range for your standard synth LFO) the values are:
R1 = 1k
VR2 = 500k
R2a = 4.7K
R3 = 4.7k
C1 = 4.7uF
See the attachment schematic - (a modified Mikmo circuit)
These values give a duty cycle of the LED of about 50% over the entire 0.3 - 30Hz range, which is also important for a synth LFO.
Cheers, Graham
 Filesize:  38.96 KB
 Viewed:  238 Time(s)
