dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
Oval
Posted: Sat Sep 23, 2006 9:47 am Post subject:
Re: Nomad working on Micro Modular Subject description: Nomad working on Micro Modular |
[quote="chresan"] | sonicacid wrote: | Hi,
Beside that next version of Java (1.6) should bring advantages in rendering time. And in the future it will be possible to enable the opengl- or directDraw/direct3D pipelines for java applications, this will bring further advantages.
Christian |
Did you ever try
java -Dsun.java2d.opengl=true
or
System.setProperty("sun.java2d.opengl", "true");
in 1.5 ? |
chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Sat Sep 23, 2006 10:36 pm Post subject:
| Oval wrote: |
Did you ever try
or System.setProperty("sun.java2d.opengl", "true");
in 1.5 ? |
Yes, I did. But I decided not to tell about it here. Using the opengl rendering might lead to vm crashes in 1.5. When the crashes are gone in 1.6 or later I will recommend this feature, but not earlier.
Christian _________________ ----------------------
http://nmedit.sf.net |
eposk
Joined: Apr 29, 2005 Posts: 155 Location: Portland, OR
Posted: Tue Oct 03, 2006 8:56 am Post subject:
to do list for the next version of Nomad-
-Randomizer
Im just looking for one button that randomizes all the knobs, similar to the access virus random button, or something similar. This would be an excellent addition to a classic synth.
cheers. |
VenaViola
Joined: Oct 29, 2006 Posts: 7 Location: Benevento Italia
Posted: Sun Oct 29, 2006 6:39 am Post subject:
Nomad on the tiger 4.6 |
I have nord modular editor java.....oh the my ibook g4 with osx 10.4.6. It isn't run  |
chresan
Posted: Sun Oct 29, 2006 7:42 am Post subject:
Re: Nomad on the tiger 4.6 |
| VenaViola wrote: | I have nord modular editor java.....oh the my ibook g4 with osx 10.4.6. It isn't run  |
Have you installed Plumstone ? (available here http://www.mandolane.co.uk/ )
In the nomad directory there is a log file 'nomad.log', can you post it here - it might contain information about the problem
VenaViola
Posted: Sun Oct 29, 2006 8:19 am Post subject:
this is error :
ibook-g4-di-venaviola:~/documents/nomad VenaViola$ java -jar nomad.jarException in thread "main" java.lang.UnsupportedClassVersionError: net/sf/nmedit/nomad/core/nomad/Nomad (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
i have install plumestone but isn't run nomad i have jse 5.0 |
chresan
Posted: Sun Oct 29, 2006 11:04 am Post subject:
| VenaViola wrote: | ... i have install plumestone but isn't run nomad i have jse 5.0 |
I have done some research on this error. The problem is probably caused because you are running an older java interpreter. Please check the java version with the command . If it is an older version than java 5.0 (1.5) you have to make Java 5 the default java VM on your computer. Please let me know when you still need help or if this solution fixed the problem.
VenaViola
Posted: Sun Oct 29, 2006 12:31 pm Post subject:
| the version of my java pakage is 1.4.2. I download this pakage from apple site |
Joined: Apr 03, 2004 Posts: 19623 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Oct 29, 2006 2:09 pm Post subject:
| VenaViola wrote: | | the version of my java pakage is 1.4.2. I download this pakage from apple site |
Sounds like the same problems that Sven (3phase) had initially - see first page of this thread for more info. _________________ Jan |
VenaViola
Posted: Mon Oct 30, 2006 10:00 am Post subject:
The nomad interface very very cool!!! i have install the plum stone v 1.3 and have setting my midi device (motu828mk2) but the nomad sw not load or transmit the patch  |
chresan
Posted: Mon Oct 30, 2006 11:59 am Post subject:
| VenaViola wrote: | The nomad interface very very cool!!! i have install the plum stone v 1.3 and have setting my midi device (motu828mk2) but the nomad sw not load or transmit the patch  |
There are several cases you could check:
1. Look again in the file 'nomad.log' if there is something mentioned about an exception. If so then post the log file here.
2. There is a known bug in the midi configuration dialog. When your midi interface has more than one in/output ports and when they have all the same name in the connection dialog then you should try the first port of the midi interface (Port A or Port 1).
Note that you have to use the Menu Synth->Download to Slot XY to send the patch to the synth.
bankbot
Posted: Thu Nov 02, 2006 4:14 pm Post subject:
Nomad on itelmac |
| Hey everyone, I was wondering if anyone had tried using nomad on an Intelmac such as the macbook and if they had had any success? |
Oval
Posted: Fri Nov 03, 2006 4:54 am Post subject:
| chresan wrote: | | Oval wrote: |
Did you ever try
in 1.5 ? |
Christian |
Hi Christian!
May be you are interesting in this - http://forum.java.sun.com/thread.jspa?threadID=782276&tstart=0
And may be you will add playing test midifiles feature in your program to check out edited patch. |
VenaViola
Posted: Fri Nov 03, 2006 5:08 am Post subject:
| exscuse me exsiste jre 5.0 (1.5) for os x 10.3.9? |
bankbot
Posted: Fri Nov 03, 2006 12:30 pm Post subject:
Intelmac Nomad Problems |
| Hey everyone, I tried the nomad on an intelmac and it fired up but for some reason it wouldnt recognize the midi in/out device that was installed and plugged into the computer. Has anyone else had problems with the nomad not recognizing their audio/midi card? |
chresan
Posted: Sun Nov 05, 2006 8:54 am Post subject:
| VenaViola wrote: | | exscuse me exsiste jre 5.0 (1.5) for os x 10.3.9? |
Hi, I am sorry but I cannot answer your question. I have searched a while for an answer, but it seems that for JSE 5 you need os x 10.4.2 or later. But you should try and ask your question in a apple forum ( theres is one on apple.com ) _________________ ----------------------
j
Posted: Fri Dec 22, 2006 5:58 pm Post subject:
| Wow.The possibilities of performances and a random patch button or mutator made me decide there is no way i will sell my nm1 keyboard! |
mynameisstuart
Posted: Sun Dec 24, 2006 3:55 pm Post subject:
deleting in the editor |
| hi all, this is a great program!!! just one thing i can't delete things in the editor like osc, filter etc. i've tried everything hilight it 'apple delete' 'control delete' everything. if someone could tell me how to delete i would to so grateful. |
chresan
Posted: Thu Dec 28, 2006 1:21 pm Post subject:
Re: deleting in the editor |
| mynameisstuart wrote: | | hi all, this is a great program!!! just one thing i can't delete things in the editor like osc, filter etc. i've tried everything hilight it 'apple delete' 'control delete' everything. if someone could tell me how to delete i would to so grateful. |
The pre release does not support keyboard shortcuts, you have to wait for the next release. _________________ ----------------------
mynameisstuart
Posted: Fri Jan 19, 2007 12:47 pm Post subject:
setting up with a midisport 2x2 |
hi, i'm having a few problem getting started with this software. i can't get my midi interface to work and sync up. PLEASE PLEASE HELP ME
cheers stuart |
chresan
Posted: Fri Jan 19, 2007 1:28 pm Post subject:
Re: setting up with a midisport 2x2 |
| mynameisstuart wrote: | hi, i'm having a few problem getting started with this software. i can't get my midi interface to work and sync up. PLEASE PLEASE HELP ME
cheers stuart |
Hi Stuart,
which midi interface do you have ? And does the midi device dialog contain duplicate entries ? If the log file nomad/nomad.log contains errors can you post the file here ?
Christian
Edit: Ah, I missed the changed subject. I have also the midisport 2x2 and it should work. But depending on your os you can only use Midi In A and Midi Out A. _________________ ----------------------
Gothboy
Joined: Feb 21, 2006 Posts: 361 Location: New England States
Posted: Sat Feb 03, 2007 7:05 am Post subject:
Can the Nomad editor work with Panther 10.3.9? I'm not running tiger but I'd like to check out the editor. I also wanted to know if Java Runtime 5 is compatible with Panther. I know this thread is a little old but my dedicated Opcode 3 midi interface died a mysterious death so I need to run the editor from my main G4 machine. I have the Clavia beta but I'd heard about the Nomad project. Thanks. _________________ Apple Mac Pro 2.66 GHz. Intel Xeon Quad core
9GB RAM
Snow Leopard 10.6.8/Pro Tools 8.0.5 Digi 002R
M-Audio Radium 61/Novation Remote Zero SL/AlphaTrack controllers
Automap 3.7
Fxspansion VST-RTAS adapter
Networked to>
G4 Dual 1.4 processor 1.25GB RAM
Pro Tools 7.3.1cs8/Tiger 10.4.11
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
chresan
