  Muied Lumens Frequencies
Open hi-hat
Page 1 of 1 [8 Posts]
nbozic
PostPosted: Fri Jul 21, 2006 6:31 am    Post subject: Open hi-hat
Subject description: what's the programming theory?
I'm having some issues with programming a professional-sounding open hi hat.
So I wanted to ask you this: What is the "theory" behind programming one that sounds like a typical trance/techno hat?
The thing I already know is that it can be created by simply using white noise and shaping it with an envelope generator. Although this does produce a decent sounding "closed" hi hat, it's not very helpful when trying to create the "open" version. I'm sure it's more complicated...
I attached a .wav sample of what I would like it to sound like, and I also attached a patch of what I have so far...
I would appreciate any pointers.
hat.pch2
Open hi hat, needs improvement
 Filename:  hat.pch2
 Filesize:  1.89 KB
 Downloaded:  752 Time(s)
DJS101670.wav
Open hi hat sample
 Filename:  DJS101670.wav
 Filesize:  47.58 KB
 Downloaded:  442 Time(s)
Audio files: 143
PostPosted: Fri Jul 21, 2006 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't generally program sounds like this, but it sounds like this would be a good case for some kind of formant filtering. You can make that up with a few bandpass filters in parallel. Also, you are doing the volume envelope and the the filter envelope together. I would suggest putting the output from the filter through the reverb module (maybe some other processing) and then run that through a VCA/EG.
nbozic
PostPosted: Mon Jul 24, 2006 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'll expiriment with what you suggested and I'll see if I can come up with something.
sheridan
Audio files: 27
PostPosted: Mon Jul 24, 2006 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there.
Basically, hat sounds are made up from extremely complex patterns of enharmonic partials... which can reasonably be recreated using FM. In particular, by using pairs of oscillators, using one square wave to frequency modulate another square wave (preferably not with a 50% duty cycle, ie. pulse waves). Then simply shape and filter to taste. Very Happy Distortion can also help.
More detailed information can be found here:
http://www.soundonsound.com/sos/Jul02/articles/synthsecrets0702.asp
http://www.soundonsound.com/sos/Jun02/articles/synthsecrets0602.asp
If you like, you are most welcome to use the hi hat and other drum sounds that I programmed which can be found here:
http://electro-music.com/forum/topic-7037.html
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
nbozic
PostPosted: Mon Jul 24, 2006 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, thanks for your help! Very Happy
3phase
G2 patch files: 141
PostPosted: Mon Jul 24, 2006 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
sound on sound is an amazing magazine...especially compared to the german keyboard mags...
Rob
G2 patch files: 109
PostPosted: Fri Jul 28, 2006 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its very much a matter of taste, but on the G2 I personally like to use the MetNoise module instead of the Noise module for most cymbal-type sounds.
When the Freq input is modulated with a random signal, but the input knob is opened just one tick, the sound of the MetNoise module gets very lively.
Some distortion like with the ShpStatic module can give the MetNoise module some extra grittiness.
It is often a good idea to use a separate Env module for the sound of the hit of the stick on the hat and another one for the sound of the hat itself after the hit.
OpenHatsExample.pch2
Example for a HiHat sound with the MetNoise module.
 Filename:  OpenHatsExample.pch2
 Filesize:  2.47 KB
 Downloaded:  1018 Time(s)
nbozic
PostPosted: Mon Jul 31, 2006 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob.
