"Filter FM amount" modulation
Page 1 of 1 [4 Posts]
arny
PostPosted: Fri Aug 04, 2006 10:20 am    Post subject: "Filter FM amount" modulation Reply with quote  Mark this post and the followings unread
Is it possible to modulate the "filter fm amount" ore the "oscilator2 fm amount" by a envelope?
I only know how to modulate the "osc. 1 FM Amount"...
sunny pedaal
Audio files: 12
PostPosted: Sun Aug 06, 2006 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
guess it's not possible.
greetings, sunny
juno6
PostPosted: Fri Aug 25, 2006 7:14 am    Post subject: partial solution Reply with quote  Mark this post and the followings unread
I´m new on this forum. I bought an A6 last week but I don´t have it yet. Looking at the block diagram, a partial solution would be to use a square/pulse wave in the osc that will be used as the filter modulator and modulate it´s square wave level. Use the other osc as sound source if you want, or use it to modulate a self-oscillating filter.
Couldn´t check it but it should work.
JZ:
juno6
PostPosted: Fri Jul 27, 2007 2:06 pm    Post subject: Re: partial solution Reply with quote  Mark this post and the followings unread
JZ:
Now I can say I was right. Laughing
JZ:
