probleme file format
Page 1 of 1 [13 Posts]
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 10:01 am    Post subject: probleme file format Reply with quote  Mark this post and the followings unread
what does it means when i download a patch and this message appear :
can't load file. file format is not supported.
Is there because i've got an unexpanded G2 ?
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
No, the file is corrupted, or it is not a G2 patch, or it is a file of a newer version than the OS in your synth is.
You can open the file in a text editor, but only the file header is readable text. It should look like :
Code:
Version=Nord Modular G2 File Format 1
Type=Patch
Version=23
Info=BUILD 266
In the help/about screen of the G2 editor you can see the version of the editor which is the same version as the OS in your synth.
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
i've got the latest version of the G2 and i load the patch in the G2 section of this site.The last time i can't open a file is on the site of ivity who post some patches on this site.
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you post a link here to a patch you are having trouble with ?
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course i can. Very Happy
this patch could not open on my G2
orange.prf2
 Filename:  orange.prf2
 Filesize:  148 Bytes
 Downloaded:  601 Time(s)
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry i post the patch 2 times. Crying or Very sad
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not a patch file, the contents of the file are :
Code:
WARNING: SYSTRAN did not translate the document entirely. The document exceeds the maximum size allowed by the solution.(2048 bytes for plain text)
No idea where this comes from though, not even if it was caused by electro-music, or by the sender or whoverer ...
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
You can try to edit the post Very Happy
(it has a button above it which says "edit")
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It is an ivity patch that i find on is site. Smile
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
darwen wrote:
It is an ivity patch that i find on is site. :)
I'm sorry, its not in the patch archive, can you post a link to the page where you found it ?
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
www.bl-project.com/G2.htm
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You'll have to complain with the webmater of that site I'm affraid, there are more things not working ok there with patches.
darwen
G2 patch files: 5
PostPosted: Sun Aug 13, 2006 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help blue hell Very Happy
Niio1
