suggestions for a 4P4T logic switch?
Page 1 of 1 [8 Posts]
SuperKoopa
PostPosted: Tue Aug 15, 2006 10:50 am    Post subject: suggestions for a 4P4T logic switch? Reply with quote  Mark this post and the followings unread
Hi!
I want to built a 4P4T using a logic circuit ( something like flip flop) and four momentary push buttons .
I don't know if you understand me but when you have a rotary 4P4T switch you can't jump from position 1 to position 4 directly.This is why I want 4 momentary push buttons that I can push indipendently .
Please Help me ,I know that It isn't a too much complex thing to do but I don't understand nothing of logic circuits!
Audio files: 107
PostPosted: Tue Aug 15, 2006 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
What are you going to switch with this device?
Is it bidirectional (4 in -> 1 out and 1 in -> 4 out)?
SuperKoopa
PostPosted: Tue Aug 15, 2006 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want to build a 4* Ds7 clone and drive it with a simple 16 step gate sequencer with four columns of 16 position dip switces.
In this way i have four different preset sequences for each output.
I don't know if you have understand
Look at the picture: the green square is the sequencer (with 16 Outputs)
each of these 16 Output is Connected with 16 pins of each dip switch (red squares).
Each output of dip switches is connected to the 4P4T switch (yellow square) , the red line means that each toggle is dependent to the others.
Connecting the outputs to the four trigger inputs of my 4*ds7 i will get a presettable drum machine.
Have you understand what i need ?
 Filesize:  32.27 KB
 Viewed:  2493 Time(s)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Aug 15, 2006 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
They used to sell mechanical push switches that interlocked in banks. Pressing one would make any other that was pressed down, pop up.
The original 'radio button'.
Are they extinct now?
A digital solution would be much cooler.
bugbrand
PostPosted: Tue Aug 15, 2006 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
This Programmer article from Synapse Magazine may be of use.
Its a matrix of presets.. I made one that's three by three and its pretty damn useful - parts of it may give pointers to making what you're after
http://www.bugbrand.co.uk
SuperKoopa
PostPosted: Tue Aug 15, 2006 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks to all!
Hey bug I don't really understand what is the core of the schematics that you've linked.
I don't need any pot ,just four push switches.
Can you help me to separate the part of the circuit that interest to me?
bugbrand
PostPosted: Wed Aug 16, 2006 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Well... lets try to sum it up::::
(we'll take a 3 by 3 matrix like I built as an example)
Imagine a grid three by three - so each column has three knobs and at the side of each row there's a button. In each column, one knob is active at any time - selected by the row button you pressed last (or was triggered).
So the core that I figured was important for you was the way that it selects the row dependent on which button was pressed last -- ie, only one row selected at any time.
This design can be expanded in either direction... Yes, took me a while to get my head around it..
Looking at the schematic:
1) The bit on the lefthand side - I left this off in my one - this generates a common pulse - so makes a pulse whenever ANY of the buttons is pressed.
2) You only need ONE of the transistor bits at the bottom -around point C - this makes sure that only one button can be active at any time.
3) the other transistor parts are then repeated for each button - you get a Button or Row output at the common join point for pots P1 -> Pn. So when the row's button is pressed (or a trigger input is received) the voltage will be high at point P1 -> Pn.
4) there's then the summer - one required for each column - but you'd maybe be changing this part for your design..
4)
SuperKoopa
PostPosted: Wed Aug 16, 2006 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks bug I'm shure that you are a real electronic expert but with transistors i'm a dumb Rolling Eyes
Sorry!
I've experimented some circuits with a simulation software.
I can turn on and off four leds with four flip flops and four triple OR gates.
If the voltage that came out from each flip flop is big enough I can drive four NPN transistor for each flip flop , or one 4066 chip for each flip flop.
Rigth?
 Filesize:  30.49 KB
 Viewed:  2440 Time(s)
