Unsure of what connections to make, in an unfamiliar world
Page 1 of 1 [5 Posts]
mapmouth
PostPosted: Wed Sep 20, 2006 11:53 pm    Post subject: Unsure of what connections to make, in an unfamiliar world
Subject description: Running Laptop live with foot switches etc.
Hello all!
I have been playing in a live band with a drum machine for a while now, and have been using fairly primitive equipment (dr670), and inevitably have run out of memory space! I'm going to upgrade to a laptop, but am unable to grasp how I can plug it into an amp, how I can control the laptop from the front of the stage with foot-switches, what other hardware I need etc. Basically I really need a step-by-step process of exactly what hardware/software I need in between the Laptop and Amp to do this sort of stuff, model names/numbers aren't too important at this point. I am decidedly unfamiliar with any of this equipment so if anyone can lend me an understanding hand out of this digital swamp I would be very very grateful, and will help out anyone else when/wherever I can!
PS: I've looked over a few posts on similar topics but unfortunately, there was still a lot of information I couldn't find/couldn't understand, if someone could help me out that would be great!
Cheers!
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Sep 21, 2006 4:55 am    Post subject: Re: Unsure of what connections to make, in an unfamiliar wor
Hi mapmouth
welcome to electro-music.com
connecting the audio output of your laptop to the inputs of a PA system or connecting the audio output of a an audio interface (conncted via USB of Firewire to your laptop )to the inputs of a PA system
you need a USB to midi interface (that could be inside the abovementioned audio interface) to which you connect some kind of control surface that include footswitch inputs.
(easier done than explained Very Happy )
bigtex
PostPosted: Thu Sep 21, 2006 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.m-audio.com/forums.html?do=products.list&ID=audiointerfacekb
One of these will do everything. Audio in/out, some keys and knobs and sliders, and some MIDI connectivity to other devices. Other manufacturers make similar devices as well.
The other option would be to get just an audio interface that had a MIDI port and pick up a MIDI footswitch (if footswitches are what you are looking for, as you mentioned).
bigtex
PostPosted: Thu Sep 21, 2006 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are a couple more:
http://www.roland.com/products/en/PCR-1/index.html
http://www.line6.com/toneport/kb37.htm
mapmouth
PostPosted: Tue Sep 26, 2006 12:26 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thankyou very much guys for helping me out, I'm new to this site and have found it very useful and the people very helpful. I'll definitely try and help anyone else out wherever I can. Thanks again!
