Korg triple resonator schematics?
Page 1 of 1 [19 Posts]
Coriolis
PostPosted: Wed Sep 27, 2006 12:16 pm    Post subject: Korg triple resonator schematics?
Subject description: Didn't someone here have them? Scott Stites?
Benn trying to find the schems for these - supposedly they are on Jürgen Haibles site, but I can't find them there!
Anybody got them?
C
Scott Stites
Audio files: 96
PostPosted: Wed Sep 27, 2006 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got'em somewhere. If you go through JH's PS3100 clone, you'll find a modified version of it that he did, which no doubt sounds absolutely out of this world. But, I'll check my archives - I still have it on breadboard, as a matter of fact (very, very sweet function).
Scott
yusynth
PostPosted: Wed Sep 27, 2006 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
These can be found at www.synthdiy.com and also at hypereal, and on RJB sdiy site as well :
http://www.synthdiy.com/files/2006/KORGRS1.gif
http://homepage2.nifty.com/rjb/diy_synthe12.htm
http://homepage2.nifty.com/rjb/pdf/rjb_diy_synthe_701a_resonator_schem_revA.pdf
http://machines.hyperreal.org/manufacturers/Korg/PS-synths/schematics/ps3100-res-1.gif
http://machines.hyperreal.org/manufacturers/Korg/PS-synths/schematics/ps3100-res-2.gif
Yves
Coriolis
PostPosted: Thu Sep 28, 2006 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Yves!
I trawled through Jürgens pages on the PS3100, but all I could find (that I could partially understand) was this:. But where is the filter core?
I would like to see what he's done with it, but then again, the circuit looks so simple, even I could probably breadboard it!
I assume those vactrols are VTL5C3/2 types? Or is there some sort of mojo in having 2 separate LED's shine on 2 separate photocells (relating to, say, a diode drop between the 2 LED's in series)?
C
yusynth
PostPosted: Thu Sep 28, 2006 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Well actually I have no experience with vactrol and LED+CDS at all.
On the RJB site, you have an interesting assessment of both devices. Although it's in Japanese one can get a fair idea (yet weird sometimes) of what is said using the Babel fish translator :
http://babelfish.altavista.com/translate.dyn
Yves
Coriolis
PostPosted: Thu Sep 28, 2006 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, yes I suppose Babelfish helps a bit.
One thing is a bit unclear to me though: is it the filter resonance that is under cv-control, or the frequency? I don't see a frequncy control anywhere, so it would appear that those are preset values... Question
C
yusynth
PostPosted: Thu Sep 28, 2006 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it's the frequencies of the three cells that are under CV, the resonance of these filters is fixed (and is around Q=5).
If you look at the schematic ps-3100-res-2.gif from RJB, you have three pots called 1st peak, 2nd peak and 3rd peak. These let you set the central frequency of each filter. Then a CV applied either to point 7 or 8 or ps-3100-res-2.gif let you modulate the frequencies of all filters.
If you wish you can add also a separate CV for each filter by adding a separate input resistors at the bases of Q102,Q103 and Q104.
Yves
Scott Stites
Audio files: 96
PostPosted: Thu Sep 28, 2006 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I highly recommend this, too - it really adds a lot to the function of the resonator. JH took real advantage of this, and, if I'm not mistaken, was instrumental in the development of the MAM RS3, which is based on the resonator circuit. To get an idea of the effect that can have, read this:
http://www.midiwall.com/gear/rs3.html
Scott
Coriolis
PostPosted: Thu Sep 28, 2006 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I'm slowly getting the picture...
Think I heard an RS3 demo on the MAM website once - very nice!
I see JH uses 5C4/2's for vactrols.
This is now on my todo list! Very Happy
Thanks guys!
C
Scott Stites
Audio files: 96
PostPosted: Thu Sep 28, 2006 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
First time I ever heard one was on Jeff Pontius' SynthImagery album. I emailed him and asked him what kind of crazy phase shifter he had - he replied that it wasn't a phase shifter, but was in fact the RS3. Later, the first time I visited him, he let me play his Prophet 5 through it - I literally went weak in the knees, it sounded *that* good.
Scott
sneakthief
PostPosted: Mon Oct 02, 2006 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Coriolis - The filter core is here in the middle: http://jhaible.heim.at/polykorg/jh_3200_signal_1of4.gif
Jurgen used VTL5C4/2's, while if I'm not mistaken, Scott used VTL5C3/2's.
I was planning on building this for a couple of months now and am about to order the parts for it Smile
What I'm wondering is which one will sound better for this application:
michell
Sneak-Thief - raw electrofunk
Coriolis
PostPosted: Tue Oct 10, 2006 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, thanks for pointing that out to me!
I saw the vactrols, but not the opamps I thought were supposed to be there.
I guess JH used discretes instead.
Vactrols:
If I understand those numbers correctly, then the 5C4/2 is a lot slower to turn on and off, than the 5C3/2, yes?
Which would give a more sluggish, "muddy" sound, I guess.
Don't know if that's desirable in this case, but then JH used them, so...
C
sneakthief
PostPosted: Tue Oct 10, 2006 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
scott told me he used vtl5c3/2's and they sounded great. after perusing all of the schematics, that seems to be a good enough answer for me Smile
Coriolis
PostPosted: Tue Oct 10, 2006 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree. Also, they seem to be preferred in a bunch of other vactrol circuits I'd like to build sometime, so they would come in handy anyway.
May I ask: Where are you getting yours?
C
sneakthief
PostPosted: Wed Oct 11, 2006 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
The cheapest electronic supply place for vactrols is here:
http://www.alliedelec.com/
However, it's way easier to order them from http://bridechamber.com (who specialize in modular synth products & parts). They're cheaper than smallbear.
michel
Coriolis
PostPosted: Wed Oct 11, 2006 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Didn't know that one. A fairly limited selection so far though. And where are they located? US? EU?
Looks like they could get interesting though...
C
sneakthief
PostPosted: Wed Oct 11, 2006 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bridechamber just opened shop in the US a couple of months ago.
PostPosted: Mon Oct 16, 2006 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
what about
http://www.banzaieffects.com
they're located in berlin, germany
or
http://www.musikding.de
they're situated in germany, too.
both are a good source for obsolete parts and particular das musikding is fast...
sneakthief
PostPosted: Mon Oct 16, 2006 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
if you want vtl5c3/2's, banzai and musikding cost more than twice as much Sad
