Can I mod an LFO for both level and rate?
Page 1 of 1 [5 Posts]
rufuss sewell
PostPosted: Wed Sep 27, 2006 1:17 pm    Post subject: Can I mod an LFO for both level and rate? Reply with quote  Mark this post and the followings unread
I like to add a little pitch and filter LFO with aftertouch but I'd like to increase the speed a bit along with the intensity. It looks like the LFO's only offer one mod source. Is this correct? Or is there a work around?
sunny pedaal
Audio files: 12
PostPosted: Thu Sep 28, 2006 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
modulate the speed via the mod of the lfo,
modulate the intensity at the destination mods, b.e. at the osc and or filter.
rufuss sewell
PostPosted: Fri Sep 29, 2006 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.... I only see frequency and resonance as mod destinations in the filter. What am I missing here?
I'm pretty sure I can't do what I am describing unless there is a way to modify two different destinations on the same LFO. Bummer.
sunny pedaal
Audio files: 12
PostPosted: Fri Sep 29, 2006 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
afcourse you only see cutoff and resonance as Destinations for a modulator!
the lfo is the Source.
the frequency /speed of the lfo is modulated by the mod on the lfo, in your case modulated by the aftertouch
the amount /intensity of the lfo effect is modulated/ controlled by the mod of the filter and or oscillators . the effect of the lfo that way can be bigger or smaller by : you first set lfo as modulator source of the filter ( making it control the cutoff or resonance and THEN go to the CROUTE page and make the aftertouch control the mod also ! ( do so by clicking the ribbonbutton)
so the idea behind that is that via croutes you can control/ modulate other modulations, something like one level of modulation upon another./ one ( lfo ) modulates the filter and the other ( croute- aftertouch) modulates the amount of the first modulator ( the lfo)
unfortunately i can't draw it out to you, a signalflow drawing would maybe make it more clearly.
i know it's difficult to get hold of it , but once you get the idea it's really simple and can be used often.
by the way guess it's a good idea to read the manual ( at least twice) completely and also to download the tricks and tips manual and also read that one completely at least once. really opens up a new world maybe.
fr. gr. sunny
rufuss sewell
PostPosted: Fri Sep 29, 2006 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, cool. Thanks! I didn't know about the croutes menu yet. I've read the manual, but things don't stick until I try them in real life. I've been going through the tips and tracks one at a time and making my own patch with each tip. But it's a slow processes. I just wanted to get this one concept down since I use it so often.
I have several simpler analogs and a Kurzweil K2600 that I know inside out. The Andromeda seems to use the best of both worlds. But the Kurzweil has an huge abundance of modulation sources and destinations, so I'm a bit spoiled.
