<on air> bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » MAX/MSP - Pd
Specific MAX/MSP questions.
Page 1 of 1 [7 Posts]
w minor
PostPosted: Thu Sep 28, 2006 6:20 am    Post subject: Specific MAX/MSP questions.
Subject description: Swing? Skins ?
Just getting into using MAX at the moment to build a ryhthym generator that will be used to trigger midi samples. I have two questions:
1. Is there any way that i can incorporate some sort of groov or swing into the metro objects, or create some kind of groove patterns for the output?
Preferably i woul like to then be able to modulate this via a MIDI controller.
2. How easy is it to skin a finished patch to something more user friendly and astheticly pleasing? i know i'm getting a bit ahead of myself here but there's no harm in asking.
Thanks
w minor
w minor
PostPosted: Thu Sep 28, 2006 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
a third question:
How can i send the MIDI outputs of MAX inside my system to the MIDI in of Cubase or a stand alone sampler like NI Battery?
I don't need things spelt out for me but if someone could point me in the right direction that would be great.
Thanks
w minor
Alexander
G2 patch files: 4
PostPosted: Fri Sep 29, 2006 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Read and work through MAX tutorials number:
12, 13, 16 and 19 !!
Then try to create an easy sampleplayer, examples are found in the msp tutorial patches and various online resources.
Creating swing and designing a personal skin is something to worry about after you finished a working patch. Tutorial 19 is all about making patches user friendly!
Good luck.
http://husc-sound.com
w minor
PostPosted: Fri Sep 29, 2006 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
cool man thanks for your help...
i have done some of the earlier tutorials but was too impatient to carry on with them...
i'm using max only at the moment as i have no great need to use msp for what i am doing and i have a time limit on the project so i don't want to spend unnecessary time learning to make a sample player in msp till i need to.
Will keep you posted and let you know how it goes.
skinnyjabba
PostPosted: Fri Sep 29, 2006 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
heres a free program that will do the trick, midi yoke: http://www.midiox.com/index.htm?http://www.midiox.com/myoke.htm
w minor
PostPosted: Sat Sep 30, 2006 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Right:
I've got to this stage:
I have crated a patch that send midi signals to specific midi note on each beat with user variable probability settings... it works pretty well.
Now i would really like to be able to add some groove or swing, i see this as the next logical step... can anyone point me in the right direction?
thanks
flowersniffer7
PostPosted: Wed Dec 06, 2006 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.maxobjects.com/ I would check here... if they have an external anywhere it will probobly be listed there.
mps board
