<on air> bingsatellites Mostly Ambient
Hey everybody.
Page 5 of 5 [113 Posts]
Goto page: Previous 1, 2, 3, 4, 5
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Apr 24, 2007 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought it was just a lay out case. When you are quoting yourself, 'Edit' is the first button on the right, where normal (other messages) 'Quote' is positioned.
Wout
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Apr 24, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
not sure what happened to that last post,
Here is a mono unison version, the manual says 2 and 4 voices are used for poly and mono unison respectively. I agree that the poly unison could be handled with just a two slot prf, nl2g2 could take care of the pan and detune automatically.
Although if the LFO's are in mono mode, then there would be no need to duplicate them or the envelopes and mixers, save some dsp overall. I'll try to do a poly-unison version as well.
Edit: Here is the poly-unison, it wont get more voices but the small saving in dsp will allow for more stuff to be loaded into other slots.
lead2g2-Uni.pch2
 Filename:  lead2g2-Uni.pch2
 Filesize:  3.25 KB
 Downloaded:  673 Time(s)
lead2g2-PUni.pch2
 Filename:  lead2g2-PUni.pch2
 Filesize:  4.22 KB
 Downloaded:  662 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Apr 25, 2007 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just testing isn't that much fun...
So I got inspired by the FilterEnvelope testing, using HighResonance on a BandPassFilter.
Wout
ArppeggioHighResFilterReleaseFireworks.mp3
Replaced lost file
 Filename:  ArppeggioHighResFilterReleaseFireworks.mp3
 Filesize:  154.62 KB
 Downloaded:  288 Time(s)
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Wed Apr 25, 2007 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was a real Nord Lead 2, right?
Albert
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 26, 2007 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
It is that kind of sound one seldom programs on a NordLead, but it is possible.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 26, 2007 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
This is also a single NordLead2
Using the Arpeggiator and LFO1 (bass drum), Filter on HighResonance and Morphing using the Wheel this little sequence shows what the NL2 can do, sometimes. At the end the Distortion is shut off.
Wout
NL2-Sequence04.mp3
Replaced lost file
 Filename:  NL2-Sequence04.mp3
 Filesize:  755.23 KB
 Downloaded:  246 Time(s)
NL2-Sequence04.syx
Replaced lost file
 Filename:  NL2-Sequence04.syx
 Filesize:  139 Bytes
 Downloaded:  79 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Apr 29, 2007 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm still busy to make the measurements Smile
Just one module to go.
Had a special lecture by Rob Hordijk 'why' those values are so different in each synth and by different manufactories...
And why computers aren't that stable as we think (1/8 note at 120 BPM isn't always 125 ms) and what the sample rate has to do with it.
AFAI(K) and Rob knows the sample rate of the NL2 at once side and the NM Classic and the NM G2 at the other are different (44.1 - 96)
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri May 04, 2007 2:22 pm    Post subject: Re: Nord Modular G2X vs. Nord Lead 2X Reply with quote  Mark this post and the followings unread
bbw wrote:
if someone has already created an Nord Lead 2X emulation patch for the G2X i'd love to hear from them. if not, i plan on attempting one, & then plan to re-create the factory patch set for the 2X on the G2X.
I just realized there are already a lot of NordLead emulations in the Archive. Just search for:
NordLead_Emulation_by_Martinez_Ken
and
Nord_Lead_Emulation_by_Clavia
The first one is the 'leave none used modules out' and the second one is rather poor.
What I'm searching for is a structure like the NordLead2(X), so all the possibilities are there in the emulation on the G2 platform, not just sounds...
Wout
(who is almost ready measuring Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 06, 2007 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Right...
Here are the results of the measurements on the NordLead2, maybe also interesting to others (please, control it Wink
(What shall I do with the rest of my life...)
Wout
MeasurementsNL2.zip
Replaced lost file
*.doc files LFO1 - LFO2 - ModEnv - FilterEnv - AmpEnv
 Filename:  MeasurementsNL2.zip
 Filesize:  14.85 KB
 Downloaded:  116 Time(s)
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Sun May 06, 2007 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Please, keep posting great patches Very Happy
Albert
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 06, 2007 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the pdf.
(edit: pdf got lost)
bbw
PostPosted: Wed May 16, 2007 1:14 pm    Post subject: so... Reply with quote  Mark this post and the followings unread
where do y'all stand w/ the conversion? i agree w/ Wout: the point is to mimic the functionality of the Nord Lead 2X & the sounds.
on that point: i don't remember who posted above saying they played w/ a Nord Lead 2X & found it similar in character to a Nord Modular G2X - do you mean that they are both analog synthesizer emulations? because that's about where the similarity ends.
i've now had my G2X for about 2 months & it does not even BEGIN to compare to the Nord Lead 2X in terms of bad ass-ness, girth & edge. & (drum roll) THE PRESETS IN THE 2X ARE FREAKING AWESOME! almost every sound in that instrument is instantly inspirational.
the same can not at ALL be said of the the presets in the G2X, which are kind of like a limp noodle by comparison - which is the whole point of this excersize.
screw it - i am getting a 2X. i'll just live w/ the crap keyboard, or get the rack.
anyone want to buy a barely used G2X?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed May 16, 2007 2:08 pm    Post subject: Re: so... Reply with quote  Mark this post and the followings unread
bbw wrote:
... screw it - i am getting a 2X. i'll just live w/ the crap keyboard, or get the rack. ...
What ever you do, I'm sure you will make the right decision.
Wout
emSynth
