Simple Noise Source
Page 1 of 1 [4 Posts]
Zoomby
PostPosted: Fri Oct 20, 2006 12:33 pm    Post subject:  Simple Noise Source Reply with quote  Mark this post and the followings unread
Would someone help me to fully understand this circuit?
What is the first capacitor for? I'd guess it's for smoothing the supply volage, but this would be silly in a noise oscillator?
The second RC is a Highpass to remove the DC amount, is it?
Bye,
Chris
Audio files: 213
G2 patch files: 319
PostPosted: Fri Oct 20, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Both assumptions are correct.
I can see a purpose for smoothing the supply when it's a part of a synth. Oscillators and LFO's tend to draw current from the supply in spikes, these could become audible in the noise when not filtered out, thus making it less random.
yusynth
PostPosted: Sat Oct 21, 2006 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
The 100uF cap is there to filter out the residual ripples of the power supply. Even though these ripples are small they are of the same order than the noise produced by the BC548. Because, this signal is strongly amplified by the OP amps (> x2000), the ripples can be heard and a strong hhum is superimposed to the noise "signal". Therefore this 100uF is there to tackle these residual ripples !
Yves
Zoomby
PostPosted: Sat Oct 21, 2006 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much! It's clear to me now. Smile
