  bingsatellites Mostly Ambient
Reproduce Audiomulch modules ?
Page 1 of 1 [3 Posts]
onosendai
G2 patch files: 4
PostPosted: Wed Nov 08, 2006 9:15 am    Post subject: Reproduce Audiomulch modules ? Reply with quote  Mark this post and the followings unread
I don't know if you have ever use Audiomulch (http://www.audiomulch.com/) but he have some great simple sound generator like "Harmonics" and "RissetTones". Do you think it's possible to make them on G2 ?
Erstlaub
PostPosted: Sat Nov 11, 2006 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes and yes,
The Harmonics generator actually used to be slightly easier on the NM as there is a bank of 6 sine waves grouped together. On the G2 its just a case of using 6 single oscs set to sine.
The Risset Tone is a simple sine wave being swept through a range of user defines frequencies so you just need to take a oscillator pumping out a sine wave and modulate its pitch attenuator with an lfo.
I've not used mulch for a few years now but the main area where Mulch totally surpasses the NM/G2 is it's handling of audio, external processing is totally possible bu it can never be as simple as dragging a file into the sample players in mulch - that and the fact that you can't use vsts so the set of modules will always be the same give or take - you can't just goggle some new filters and install them.
On the plus side - I've never managed to crash a Nord Mod or get it to stop responding etc.
If you know your way around mulch then you get the modular life and it should be a pretty easy transition.
Good luck
D
onosendai
G2 patch files: 4
PostPosted: Sat Nov 11, 2006 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's possible Very Happy
Harmonics_01.pch2
Remake of Audiomulch "Harmonics" module. Play with fader to fade between harmonics
 Filename:  Harmonics_01.pch2
 Filesize:  1.65 KB
 Downloaded:  644 Time(s)
emSynth
