Scott Stites/Buchla 291 adaptation
Page 8 of 8 [189 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8
mph
PostPosted: Wed May 18, 2011 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
brother303 wrote:
Which 082 exactly? The lower one (next to the lp/bp/hp-outs) on the left side on Lucas´ v3-pcb?
Nope, it's the 82 which is on the middle of the left side of the pcb (U4 on the corrected schemo). The one which has three 200K resistors connected to its pin 3 on the pcb. That's the mix input section of the circuit and not the output.
You can compare to the wiring of the other 82 in the LP/BP/HP output section which is correctly connected (U5 on the corrected schematic): pin 3 should be connected to ground.
brother303
PostPosted: Wed May 18, 2011 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks mph,that`s what I needed to know.
thumright
Cheers!
Wink
Best regards
Greg
Luka
PostPosted: Fri May 20, 2011 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
fixing the layout now
i didn't use the processor
should i replace it with another mixer / buffer arrangement?
it means if you use 2 or more boards you can run in parallel mode
problemchild
melbourne australia
Luka
PostPosted: Fri May 20, 2011 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
here you go
v4
fixed the mixer section - didn't change anything else
it would be nice to completely redesign this pcb so it doesn't have all the wire links. i tried to maintain mark's filter section and it made it hard to add lots of extra circuitry without wasting space.
291_rev4.pdf
291 with mods
 Filename:  291_rev4.pdf
 Filesize:  745.76 KB
 Downloaded:  515 Time(s)
problemchild
melbourne australia
brother303
PostPosted: Sat May 21, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for offering this update,cool!
No more bugs and kludges now?
Thank god,I didn´t etch the older version ´til now... Wink
Cheers.
Best regards
Greg
Peake
PostPosted: Sat May 21, 2011 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to see a dual version like Verbos' but with the multiple output types, perhaps using a single buffer with switching for the Type. Of course, it's always nice to have independent outputs...
Luka
PostPosted: Sat May 21, 2011 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
brother303 wrote:
Cheers.
cant be sure - i haven't tested it and wont have time until 2013 as i'm about to travel overseas for a few years - my studio is all packed up.
problemchild
melbourne australia
Peake
PostPosted: Wed Jun 29, 2011 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Danger! Don't etch this! Am having slight size alterations occur when going from photoshop to pdf, and ICs won't fit correctly. Huge apologies to anyone who might have done so; from now on I'll etch and confirm everything prior to posting. Embarassed
Needing ideas please...
I'm working on revising Mark Verbos' 291 filter dual layout because it's sized for Buchla systems (4" x nearly 6"). I like the idea of a single board, or even stacking two boards for a quad setup on a single width panel.
I've built and enjoyed the Stites/Luka/etc. modified versions of Mark's board, with the buffers for LP and HP, and had wanted that and a mixer either per filter or available in a quad concept for summing, or for merely adding LP and BP for variable notch response in any single filter, then summing, etc.
So, I've added Luka's adaptation of Ken Stone's DC mixer, as well as individual buffers for this particular board size, then went a little nuts and changed the mixer in the first filter to a slightly modified MXR distortion +. It would be nice to have something like a RAT per filter, but that's a 308 opamp, and I've just used the sections of a TL084 instead.
Now, the Distortion + uses a 741 with a 9V battery, and 4.5V into a 1M to the input. The 084 is of course using 15V bipolar rails and has several times the slew rate of the 741, meaning a crisper sound (not necessarily desirable here). I'm asking what proportion is required for the 4.5V section, with the main voltage nearly twice that of the original design. Just double it to 9V and it should be well? I wanted to ask before etching, although I'll likely just have to etch and tweak anyhoo.
Also, I have one unused opamp section in the one filter and wanted to see if anyone had any sweet ideas for it (HF boost/cut, etc.) in the available space. I can see how to further tighten the distortion layout to allow a little more room for that open opamp. "What would you do?"
Thanks to all who have brought this design to this point!! I haven't added a wiring diagram as the core is still unproven. Here is the Distortion +:
http://www.premierguitar.com/Magazine/Issue/2008/Dec/MXR_Distortion_Plus_Mods.aspx
291 Dual 2.pdf
 Filename:  291 Dual 2.pdf
 Filesize:  4.79 MB
 Downloaded:  407 Time(s)
numbernone
PostPosted: Tue Aug 09, 2011 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assembled the third from my original 3 boards of 2007, has it really been so long?? WOW
So this one is again different from the other 2. Probably the most straitforward sounding of them the 3. HOWEVER this guy just wont go to the bottom like the other 2. I tend to the HP output and love to sweep the bass frequencies away and have them come rushing back with a WHOOMP. This one just. almost makes it but not quite. Mind you it will pass low frequencies, it just doenst not emphasize them like the other 2 will. Not really sure where to proceed to try and get some additional bottom.
xi-boy
PostPosted: Mon Aug 22, 2011 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
here you go
v4
hi
i am a little bit confused about the potiometer values of the current version
its still
r47 100k lin
r7 resonance 5k
r47 fm level 50k lin
r37 initial cent freq 10k lin
r40 center freq 10k lin
r41 initial bandw 10k lin
r44 band mod level 10k lin
thanks a lot
thermionicjunky
PostPosted: Tue Aug 23, 2011 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
xi-boy wrote:
hi
its still
r47 100k lin
r7 resonance 5k
thanks a lot
Those values work for me.
xi-boy
PostPosted: Tue Aug 23, 2011 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
great. thanks
L´Andratté
PostPosted: Sun Mar 02, 2014 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I have just breadboarded the circuit from the Scott Stites schematic and am positivly blown away by the beautiful sounds of it, I´m totally in resonance! cyclops
Now being a analog freak, I have to understand how it works, but altough I thought I had knowledge of the vc filter topologys, I´m kind of clueless with this one, it looks a bit like a heavily modified state variable...
Please is there anyone willing to Idea me?
Snaper
PostPosted: Thu Oct 09, 2014 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
here you go
v4
Have somebody wiring diagram for this one?
