The Thomas Henry "Clangora"
Page 2 of 4 [95 Posts]
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 16, 2006 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah there it is, good job Bill & Tom !
Audio files: 51
PostPosted: Sat Dec 16, 2006 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I've tried downloading that .pdf a number of times now, but it always comes up with an error in Adobe which says, "the file was damaged and could not be repaired"
We would lose our friends.
So,.........
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 16, 2006 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, strange ... I did not have a problem with the PDF (i'm still using version 7).
Audio files: 51
PostPosted: Sat Dec 16, 2006 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it's because I'm still using 5? Embarassed
So,.........
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 16, 2006 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably, I saw Bill mention 6 somewhere I think Very Happy
Audio files: 22
PostPosted: Sat Dec 16, 2006 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, you are correct! Very Happy Just grab the free Adobe reader 8.0 ...
This document will work with >= 6.0 .......
http://www.adobe.com/uk/products/reader/
Bill
richardc64
Audio files: 25
PostPosted: Sat Dec 16, 2006 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I hardly ever use Acrobloat for viewing. Try this:
http://www.foxitsoftware.com/pdf/rd_intro.php
PostPosted: Sat Dec 16, 2006 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I must admit that I really dislike Acrobat too. I don't have it installed here- I much prefer Preview.
ACHTUNG!
Audio files: 22
PostPosted: Sat Dec 16, 2006 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just to let you all know, Tom and I are working on getting a better looking document up on this thread so hold tight, for now, the current PDF will have to suffice. I will look at things tonight ....
After that, we can get things rolling and have some of you build these Hi-Hat synthesizers.
As promised also, I will try to get some samples of the Clangora up from my hard drive ... I know I have a few things !!
Bill
Audio files: 51
PostPosted: Sat Dec 16, 2006 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nup,
I've installed Reader 8, and I still can't get it. Always comes up with the same error. Whether I try to open the link or save as. It's supposed to be 3.8MB and the download which is saved is only 329KB.
So,.........
PostPosted: Sat Dec 16, 2006 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hold your horses Unkle K Smile
I think we are going to have to display these pages differently. It's going to take a little while. Can you hang on (to the walls? Very Happy ) for a bit longer??
Tom Very Happy
ACHTUNG!
Audio files: 51
PostPosted: Sat Dec 16, 2006 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
No stress, Smile
I just get curious when something doesn't do what you think it should. It's possibly a fault with my PC anyway.
So,.........
PostPosted: Sat Dec 16, 2006 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Time to get a Mac then?? Laughing
(you have to admit that you fell for that one?? Very Happy )
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 16, 2006 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Time to get a Mac then ??
Nah, I'll wait for Lisa jr. Very Happy
Audio files: 51
PostPosted: Sun Dec 17, 2006 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I said "fault", a fault can be tracked down and fixed.
As compared to an "as yet undocumented feature which will cost you an extra $1500 to enable" Wink
So,.........
PostPosted: Sun Dec 17, 2006 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
"undocumented feature"?
Question Question Question
My Mac turns on, it works, Period.
The only $1500 you'll be spending is on another motherboard for your peepee- whoops peecee Laughing
ACHTUNG!
Audio files: 51
PostPosted: Sun Dec 17, 2006 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Rolling Eyes Smile
So,.........
richardc64
Audio files: 25
PostPosted: Sun Dec 17, 2006 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
While you're wearing down your fingernails hanging onto the walls, Uncle, here are gifs to keep you salivating.
http://www.geocities.com/richardc64/clang/
block = block diagram
figure2 = triggers and envelopes
figure3 = clatter (noise)
figure4 = clank
figure5 = VCAs and output
I find figures 3 and 5 most interesting. "Clatter" is pitched noise generated by modulating a VCO with noise. Figure5 uses the NE570 as VCAs. New ideas to play with. Thank you v-un-v
PostPosted: Sun Dec 17, 2006 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I know what part of the problem is here now Idea
Everyone keeps uploading these images as scans, but no one is converting them to black and white, resizing or adjusting contrast and brightness etc etc. The result is a less than acceptable image.
Come on you chaps!! I know that you are only engineers, but engineers should be able to get it right!!!! Laughing
Thanks for the uploads Richard, but we really need something a little clearer. I think this is important.
ACHTUNG!
PostPosted: Sun Dec 17, 2006 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a test one- but the image is still too pixelated. This is mainly because the image was 72dpi from the offset. 72 is okay- but as long as the image is scanned at a minimum of 180dpi in the first place.
 Filesize:  89.64 KB
 Viewed:  2226 Time(s)
ACHTUNG!
richardc64
Audio files: 25
PostPosted: Sun Dec 17, 2006 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I know. Just wanted to enable Uncle K to see something while he tries to correct his pdf difficulties.
I tried to clear up the images, but going b/w made them less readable. The current pdf is still usable, if one is sufficiently motivated;-)
Audio files: 22
PostPosted: Mon Dec 18, 2006 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK fellas, I just sent our Moderator, v-un-v, a set of very acceptable images via e-mail. I am sure he will re-touch as needed and then post them to this thread to get things rolling. Again, hang tight for the "new and improved" version of the Thomas henry "Clangora" Nuts and Volts article. It's worth the wait as it is a VERY well written article and a fun project to build to boot!!!
Thanks,
Bill
Audio files: 22
PostPosted: Mon Dec 18, 2006 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about the new Macbook! I have been kicking around the idea of maybe purchasing one of those types. BTW .. gee, my PC turns on and works every time also ... Very Happy Very Happy Very Happy Very Happy I must have set it up correctly ... Wink
Bill
PostPosted: Tue Dec 19, 2006 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it's what you are used to Smile
Me and Unkle K are always winding each other up- it's all part of the fun of being on E-M.com!! Cool
But the next time I hear that line about Apple ripping off Xerox's OS.... I'LL SCREAM!!!! Twisted Evil Twisted Evil Twisted Evil Twisted Evil
ACHTUNG!
Audio files: 22
PostPosted: Tue Dec 19, 2006 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Politics, Religion, Computers, analog vs. digital, ... deadly and highly opinionated subjects Evil or Very Mad ... and, what the hell is a "warm" sound anyways? Confused
Yea, I hear you the OS thing, the PARC guys were a great think tank BUT Apple just saw something that worked and built on it ... Seriously, I am really thinking about wanting to run stuff on a MacBook.
I don't want to get too OT .... Very Happy
Bill
