Posted: Tue Dec 19, 2006 8:45 am Post subject:
Hey Bill,
isn't the NE570 a compander?
The 3080 and the LM13700 are TOAs. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Dec 19, 2006 10:08 am Post subject:
The 3080 and the LM13700 are TOAs. |
Yes, but he is not using it like a compression/expansion unit but in more of a straight VCA role. The basis of companding is the use of voltage controlled amplifiers and the close monitoring of signal levels. There are two independent sections in the NE570. With some modification of the original Clangora circuit, I would imagine that the LM13700 could be made to do the same thing as the NE570 since the OTA is the basis of most VCA's. The LM13700 is more widely available and cheaper and it has a better S/N ratio than a CA3080. Also, the Iabc control current is better isolated on the LM13700 part than on a CA3080 as I have mentioned before in other topics on the forum.
I have not looked back on the article lately in it's entirety but I believe Tom's reasoning was that two VCA sections could be made from one NE570 and that the distortion and noise specification is better using this part. So, you can make two VCA sections with one LM13700 also if you could not get a NE570.
Bill |
Posted: Tue Dec 19, 2006 3:00 pm Post subject:
Thanks for explaining that Bill.
I can see I still have much to learn.
I've learned so much hanging out here, I forget sometimes that my theoretical background is a bit shaky! _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Dec 19, 2006 6:43 pm Post subject:
Quote: | Thanks for explaining that Bill.
I can see I still have much to learn. Smile
I've learned so much hanging out here, I forget sometimes that my theoretical background is a bit shaky! Embarassed |
I am happy to help always and I personally have learned from all of you. I feel like I know you all |
Photon
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Fri Oct 19, 2007 3:29 pm Post subject:
does anyone have a clean looking, 1:1 copy of the PCB art? I've got the one from here, but its not sized so well. I'm in the process right now of re-doing one, but if one already exists why not just use that...
-justin |
Photon
Posted: Fri Oct 19, 2007 4:11 pm Post subject:
goodrevdoc wrote: | does anyone have a clean looking, 1:1 copy of the PCB art? I've got the one from here, but its not sized so well. I'm in the process right now of re-doing one, but if one already exists why not just use that...
-justin |
hey Justin
Reduce it to 64% on a photocopier and you'll be all set. I had to figure this out by trial and error. I'm weird the guy at the copier holding a 16 pin IC socket to each copy and muttering to himself.
P. |
Photon
Posted: Fri Oct 19, 2007 4:17 pm Post subject:
Bill
*very nice job*. Those little socketed modules are very cool. I've seen those before in various prototyped things at work but never worked that way myself.
I'm psyched to get this done. I etched the panel earlier today on my lunch break. I've got the PCB mostly populated so I'll post a photo this weekend.
Peter |
Posted: Fri Oct 19, 2007 5:27 pm Post subject:
Quote: | I'm psyched to get this done. I etched the panel earlier today on my lunch break. I've got the PCB mostly populated so I'll post a photo this weekend. |
Yes, I am really interested to see the result
Thanks for sharing the project.
Bill |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
etaoin
Posted: Fri Oct 19, 2007 11:27 pm Post subject:
No sound samples from mine though. I already sold it on (including, sadly, three of my four LM566's...) _________________ http://www.casia.org/modular/ |
Photon
Posted: Sat Oct 20, 2007 4:18 pm Post subject:
nice job, Etaoin.
I'm surprised you sold it. Were you disappointed with it?
Mine won't be finished as soon as I had predicted. I somehow forgot to order one of the parts. Somehow I always forget something . Must be pathological... |
goodrevdoc
Posted: Sat Oct 20, 2007 10:11 pm Post subject:
Quote: | I somehow forgot to order one of the parts. Somehow I always forget something. Must be pathological... |
If I always ordered all of the parts I probably would have been out of DIY years ago. Its that project lapse and stock of parts that keeps me building! Also thanks for the scaling advice. I tried that originally with not much success but will give it another go before re-laying out another board.
-justin |
Photon
Posted: Sun Oct 21, 2007 5:44 am Post subject:
Something is either back-ordered, I forgot to order it, they neglected to send it, its the wrong part, or the capacitors are HUGE!
If you continue to have trouble, I have the pcb image at the right size. I may even have it on press n peel. Let me check tomorrow and if I have it I could mail them to you. I'll let you know.
Pete |
Photon
etaoin
Posted: Sun Oct 21, 2007 11:03 am Post subject:
Photon wrote: | nice job, Etaoin.
I'm surprised you sold it. Were you disappointed with it? |
I never finished it. Needed the money for something else. _________________ http://www.casia.org/modular/ |
Posted: Sun Oct 21, 2007 12:06 pm Post subject:
Quote: | Here's my Frac panel design. I'll post the actual panel soon. |
I really like your FRAC layout. Very well done
Bill |
Joined: Jan 31, 2003 Posts: 18195 Location: Durham, NC
Audio files: 211
Scott Stites
Audio files: 96
Posted: Sun Oct 21, 2007 4:35 pm Post subject:
Perhaps a little OT, but save a spot next to your Clangora. Thomas wasn't the least bit unoccupied this summer...... _________________ My Site |
Photon
Posted: Sun Oct 21, 2007 5:57 pm Post subject:
Thanks everyone.
The panel is etched and I'll be drilling holes and trimming it to size tomorrow. I'll try to put a photo up of the actual panel soon.
Scott Stites wrote: | Perhaps a little OT, but save a spot next to your Clangora. Thomas wasn't the least bit unoccupied this summer...... |
I'm almost out of real estate in my cabinet. |
Thomas Henry
Joined: Mar 25, 2007 Posts: 298 Location: Southern Minnesota
Posted: Sun Oct 21, 2007 8:44 pm Post subject:
Enough of the winks. Let's start a new thread and uncork this puppy for the EM crowd.
To get the ball rolling, its name is: the Mega Percussive Synthesizer.
Modesty prevents me from mentioning it is the most versatile percussion synth ever conceived. Oops, I just did. We better let Scott take this over on another thread.
And now back to your regularly scheduled Clangora...
Thomas Henry
P.S.: no hard-to-find parts! |
23isgood
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Sun Oct 21, 2007 10:22 pm Post subject:
Oh boy. You're killing me Thomas. Keep em coming.
pete _________________ Check out my music |
bugbrand
