midgetfidget
Joined: Aug 22, 2006 Posts: 84 Location: melbourne, aus
Posted: Wed Dec 20, 2006 8:26 pm Post subject:
A question about modular signal levels |
This is probably really obvious, but anyway here goes:
I plan to make either rene schmitz's MS20 clone or maybe a polivoks clone filter to be used on audio from my synths/drum machines.
Seeing as they are designed for use in a modular do i need to add any circuitry to the signal path to do this? Amps/buffers etc.. |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Thu Dec 21, 2006 7:21 am Post subject:
I think you'd need an amp at the front end to bring the line level up to about 5V P-P. There's also a possibility that, being a filter, it would process the line level signal just fine, but the noise level might suffer depending on how noiseless the filter design was. I'd try it without first and see. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Funky40
G2 patch files: 5
Posted: Thu Dec 21, 2006 2:34 pm Post subject:
i have made an Amp modul with 10x amplification.
They told me that this is the normal amplification needed for Line Level signals.
It works very fine. ( it was my very first strippboard projekt. Very simple )
Polivoks Filter:
You can try to decrease the input Resistor i think (maybe 10k instead of 100k ). this way it should work without an extra OP Amp.
( but i'm also really beginner in electronics, understanding nearly nothing. so maybe i'm wrong )
if Polivoks, i suggest to take the UA 776 chip. Seems to be much better.
and yeah, it's great on Drums |
Posted: Thu Dec 21, 2006 4:00 pm Post subject:
| Funky40 wrote: | | if Polivoks, i suggest to take the UA 776 chip. Seems to be much better. |
did you try both, lm42450 and UA776? marc b. told me the resonnance control would be better but i never tried a Ua776... (sorry for kidnapping this thread) _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Funky40
G2 patch files: 5
Posted: Thu Dec 21, 2006 5:41 pm Post subject:
hi fonik,
no, i'm just knowing the UA776
I'm at www.synthesizerforum.de "at home".
there are some People who have tryed both.
Elektrolabel for example like both.
Serenadi recommend the UA776 ( he is one of the most experienced modular Users there in my view).
Then also Sägezahnsmoo recommends the UA776, also a very experienced Person.
With the LM 4250 it seems to sound nice, with the UA776 it seems to get the Balls.
I know somebody here who has some LM 4250 and i will see him next week,
i ask him to bring me one,and i will test it.
If all works i will make some Audio Demos |
fluxmonkey
Posted: Thu Dec 21, 2006 7:12 pm Post subject:
Re: A question about modular signal levels |
| midgetfidget wrote: | This is probably really obvious, but anyway here goes:
Ken Stone's stomp box adapter: http://www.cgs.synth.net/modules/cgs46_sba.html
b |
Scott Stites
Joined: Dec 23, 2005 Posts: 4119 Location: Mount Hope, KS USA
Audio files: 96
Posted: Thu Dec 21, 2006 7:58 pm Post subject:
Cool thing about Rene's MS-20 filter is the less signal level it sees, the more apt it is to go into self-oscillation at high resonance settings. I imagine it's probably true of the original filter, but I've never tried it on an actual MS-20.
Scott |
midgetfidget
Posted: Thu Dec 21, 2006 11:22 pm Post subject:
Thanks for the tips guys.
I'm making this to replace my beloved frostwave resonator that was stolen in a break in.
i'm pretty sure that pedal had some sort of amp/mixer built in.
Anyone have any schematics for a small 12v+/- power supply? most of the ones i've seen around are probably too big for a pedal |
softfin
Joined: Oct 11, 2006 Posts: 264 Location: Far in the north
Posted: Fri Dec 22, 2006 4:11 am Post subject:
I've heard a lot of promising comments about the Polivoks and it seems simple. So I have to consider building it too
Does anyone know where one could find ua776s for cheap in Europe? |
softfin
Posted: Fri Dec 22, 2006 6:46 am Post subject:
ua776 vs. MC1776 |
I just found out that i could obtain MC1776s for a decent price locally. I read somewhere that they are similar to UA776. I checked the specs and they are close but not exactly the same.
I would be grateful if someone more experienced than me could give the datasheets a quick look and see would the mc1776s work in the polivoks vcf.
Here are datasheets for both.
MC1776
UA776
Thanks. |
