Elektron Machinedrum Emulation
Page 1 of 1 [3 Posts]
theorist
PostPosted: Tue Jan 30, 2007 4:41 am    Post subject: Elektron Machinedrum Emulation Reply with quote  Mark this post and the followings unread
Hi all!
I want to emulate some Machinedrum sounds, but I don`t own a original Machinedrum. So I need some tips about the synthesis models that are used in the machinedrum.
I already have some experience with drum sounds, I often use the percussion OSC with a AD Envelope, Noise OSCs, Pulse OSC with BP VCFs etc. But I always make the same sounds...
Minimal Techno sounds like JPLS, Sähkö, Panasonic, M_nus, Troy Pierce etc. are the ones I like to build...maybe you have some new ideas for me...
Thanks
theo
slave to this
G2 patch files: 7
PostPosted: Thu Feb 01, 2007 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
download the manual from elektron if you haven't already. you can at least get a good look at what parameters/masterFX you will need to include in your patch. you can probably do the FM and TRX machines fairly well with a bit of time.
theorist
PostPosted: Thu Feb 01, 2007 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, thats a good idea.
