How to use midi files with presets?
Page 1 of 1 [3 Posts]
purpurkatten
PostPosted: Wed Feb 07, 2007 2:01 pm    Post subject: How to use midi files with presets? Reply with quote  Mark this post and the followings unread
I´m a newbie to sysex and need help.
How am I supposed to use midi files filled with presets?
To first make sure the A6 is ready, I´ve dialed in an empty card bank, then I´ve pressed the global button on the A6, gone to the midi page, and set syxrx (sysex receive) to -on-.
Then I´ve tried to import the midi files in a midi track in my sequencer and have pressed play, but nothing happens.
What am I missing? Question
Thankful for input.
sunny pedaal
Audio files: 12
PostPosted: Thu Feb 08, 2007 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
on the a6 it seems oke what you've done, exept that you should also watch where he'll put the sysex ( here or original location or so)
with the midi file it could be a good idea to first prepare the sequenserprogram ( what program do you use ' cubase or another?)
then after you have opened/ imported the midifile you should assure that it contains the sysex info ( just klick on the file or on list or so and see what it containes)
oke presume you have a correct file , containing sysex material in your computer and now want to sent it to the a6 , who is ready to accept it.
just press play on the sequenser ( if necessary you can reduce the playbackspeed to60bpm instead of 120, but that's an more advanced tip)
AND: be sure it outputs the sysex, that it doesn't ( by default) filter out sysex info!! this by example is the problem with cubase, you can check it under midifilters.
hope this helps a bit, good luck,
fr.gr. sunny
purpurkatten
PostPosted: Mon Feb 12, 2007 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found out how to do it with SX2 now.
Thanks a lot for the help. Smile
