ridethefader
Posted: Sat Feb 17, 2007 4:17 pm Post subject:
nord modular Subject description: no output |
okay just got a nord modular plugged it in just to hear some sounds and i have no output. the midi trigger is lighting up but no sound. when i plugged in my midi interface it had an error message oo1. so any help here would great. do i need to initialize it or anything? |
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Feb 17, 2007 5:10 pm Post subject:
This is for the NM Classic ?
BTW _________________ Jan
ridethefader
Posted: Sat Feb 17, 2007 5:12 pm Post subject:
yes. after looking at it. it asking me to load patch. so im assuming this NM doent have any patches loaded on it. im having some midi interface issues to laod somehting new. it does comes up with a error message when i plug it in. i am using a m audio firewire 410 |
Audio files: 278
Posted: Sat Feb 17, 2007 5:16 pm Post subject:
Ok, you have no sound and trouble with MIDI. Can you select patches from the front panel interface ? Any other weird things happening ?
I'll move this to the NM Classic section, but I'll leave a link. _________________ Jan
Audio files: 278
Posted: Sat Feb 17, 2007 5:20 pm Post subject:
I vaguely remember an issue that occasionally hapened with the NM Classic resulting in no sound. It had something to do with audio routing, something that is not possible in the 3.03 version but it was in earlier versions. But there seems to be traces left of old code or something. I do not remeber how it could be cured ... maybe downgrading the OS and then upgrading again to 3.03 would do the trick - you'll lose all intrnal patches in that process though. _________________ Jan
ridethefader
Posted: Sat Feb 17, 2007 5:26 pm Post subject:
i can see the patches in the lcd. it is just prompting me to load them. also it looks like i have verison 3.01. nothing weird is really happening as i go through the menu |
ridethefader
Posted: Sat Feb 17, 2007 5:33 pm Post subject:
also it looks like in the beta editor it cant find the NM via midi. so is it that the firewire 410 is not compatible? |
Audio files: 278
Posted: Sat Feb 17, 2007 5:36 pm Post subject:
Hmm, I said a not so smart thing - a bit up - re. the down/upgrade process .. when the MIDI interface won't work that's pretty hard to do probably. You could try though if the OS loader still works, if so try to upgrade to 3.03. It should not loose patches I think.
Also I vaguely remember something about clean booting, starting up while having certain keys pressed - that info never reached the FAQ I think, and I really can't remember ... sorry.
You could try to google on the secret keys, it might be in some mailing archive, very likely it is, but such info cna be hard to google.
Sorry again for just offering moral support here. _________________ Jan
Audio files: 278
Posted: Sat Feb 17, 2007 5:38 pm Post subject:
ridethefader wrote: | also it looks like in the beta editor it cant find the NM via midi. so is it that the firewire 410 is not compatible? |
Did it ever work ? Do you have a known good MIDI interface ? _________________ Jan
ridethefader
Posted: Sat Feb 17, 2007 5:46 pm Post subject:
i appreciate your help. i have used my inferface with no issues before. and the cables are working cables. what about midi to usb cable top bypass the whole interface? |
Audio files: 278
Posted: Sat Feb 17, 2007 5:51 pm Post subject:
Well it's always good to try to change things of course _________________ Jan
3phase
G2 patch files: 141
Posted: Sun Feb 18, 2007 1:28 am Post subject:
its defently possible that a midiinterface is causing the problem or is part of the problem..so you defently should try with another one to ensure that this is not interfearing with the update process.
Its possible that NM1 gets internal memory corruption... there is the issue that there are no gaps between safed patches are allowed...
regarding the system reset.. Its bad that theese info is not availible in the forum..we should try to get this information.. maybe asking the mailing list? |
Colin OOOD
Posted: Mon Feb 26, 2007 5:40 pm Post subject:
Blue Hell wrote: | It had something to do with audio routing, something that is not possible in the 3.03 version but it was in earlier versions. But there seems to be traces left of old code or something. I do not remeber how it could be cured ... maybe downgrading the OS and then upgrading again to 3.03 would do the trick - you'll lose all intrnal patches in that process though. |
Up to OS3 the NM treated the physical outputs as busses. The outputs in the patches culd be mapped to this fromt the synth settings.
(quite obscure, I remember Rob looked quite surprised when I brought this up as a advantage of v2.10)
All outputs would end up on some bus, I think so if that's it you might want to try the various hardware outputs, just lay 4 cables to your desk and listen to all of them.
If it's a bug I have no idea and no guarantees as to fixes. _________________ Kassen |
Audio files: 278
Posted: Mon Feb 26, 2007 6:24 pm Post subject:
Kassen wrote: | All outputs would end up on some bus, |
They could also be off/unrouted IIRC. _________________ Jan
Posted: Mon Feb 26, 2007 7:34 pm Post subject:
Oh.
Ooops.
So the code for that is still there, they just took out the interface? then made the updater to v3.x keep the settings?
That would be one silly oops...
Ok, so; backup, grab the 2.10 from that NordUSA topic, downgrade, change system settings , upgrade again.
That sucks. _________________ Kassen |
Audio files: 278
Posted: Mon Feb 26, 2007 7:41 pm Post subject:
Kassen wrote: | So the code for that is still there, |
I don't know that, I suspect it to be the case. I had some pretty good reasoning for it some years ago, at least I thought so. Maybe some traces are left n the email archives, but it's something that occasionally happens, the Classics loosing their sound. There was a fix as well I think, but djeez it's too long ago, I forgot all the details. _________________ Jan
Audio files: 278
Posted: Mon Feb 26, 2007 7:44 pm Post subject:
Kassen wrote: |
Ok, so; backup, grab the 2.10 from that NordUSA topic, downgrade, change system settings , upgrade again. |
That could have been it yes, the fix I mean. A down/upgrade cycle is not a bad thing to try when the Classic goes weird - except that you'll loose all the stored paches. _________________ Jan
