 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Filter/Masher 1
Page 1 of 1 [2 Posts]
iPassenger
G2 patch files: 78
PostPosted: Thu Feb 22, 2007 10:36 am    Post subject: Filter/Masher 1
Subject description: Simple home built filter unit with Saturation on input and output
After following Rob's roll yr own resonant filter guide, I came up with this little number, quite an aggressive piece of kit and I have mainly been playing drum loops thro it but i suspect it may work nicely on bass lines too.
It has a morph-able and cross fade-able filter, allowing LP, BP, HP and All Pass and variants in between.
Haven't used the morphs much as it really needs to be tuned to what yr filtering, altho they could be quite cool depending on what yr using, example on Var 8.
All the main controls on the left (coloured) and all the boring stuff (maths n that) on the right.
Hope u like.
R.
Filter Masher 1.pch2
This is only version 1, I would like to modify this to include sequenced filter cutoff and/or sequenced filter shape too. Also I used my own version of an env trigger/follower cos I couldn't seem to get any decent results out of the inbuilt module, tips
 Filename:  Filter Masher 1.pch2
 Filesize:  3.02 KB
 Downloaded:  2106 Time(s)
iP (Ross)
Rix
G2 patch files: 25
PostPosted: Wed Mar 21, 2007 3:39 pm    Post subject: Filter/Masher 1 Reply with quote  Mark this post and the followings unread
Yep, works best on drum loops. We havn't figured out what's happening with the filter morphs yet, we like your clear labeling of the functions though.
