MORE MORPH GROUPS
Page 1 of 1 [7 Posts]
gomidas
G2 patch files: 6
PostPosted: Thu Mar 01, 2007 7:37 am    Post subject: MORE MORPH GROUPS
Subject description: Please Clavia HELP US!!!!!!!!!!!!!
Why not????? Laughing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Mar 01, 2007 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Once Dave Peck suggested an extra Morph using the modulation input to a parameter and a constant module to set the morph value. Using a level scaler one can set the range. It worked in the Classic, so it has to work in the G2!
Wout
gomidas
G2 patch files: 6
PostPosted: Thu Mar 01, 2007 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Wout.I will try...
davep
Audio files: 10
G2 patch files: 73
PostPosted: Tue Mar 06, 2007 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm? Ah yes. On the NM1, I sometimes needed more than the four Morph groups so I created psuedo-morph groups using one Constant module (assigned to a panel knob) to control lots of other parameters. You route the signal from Constant module to various mod inputs, or use it to control VCAs that, in turn, control the levels of various other mod signals going to mod inputs. Use inverters, level scalers, shapers, etc. to alter the response & polarity of the Constant signal as needed on some of the destinations.
Info on this in the archives:
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/Folder/5thMorphGroup/5thMorphGroup.htm
Dave Peck
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Mar 09, 2007 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
and for those parameter who's parameters cannot be modulated (like sequencer levels or eq's you can always route you extra "morph group" or "additional morph parameters" controls mixed with an offset (a 2 mix with your morph as one input and original value as a 2nd input mixed) to a midi cc send internally and map this cc to your desired parameter ...
I rarely need more morph params ...
/Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 )
hyperstationjr
G2 patch files: 24
PostPosted: Tue Mar 13, 2007 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't morph groups basically be replaced if they just allowed a Midi CC signal to be sent to multiple sources? Isn't that basically what morph groups do?
I think if they kept the 8 standard morph groups, but added that feature, along with the ability to set range and polarity of MIDI CC's, it would be set, at least on this end...
Studio:
Akai MPC2000xl.
Behringer BCR2000.
Clavia Nord Modular G1 Key* (considering to sell/trade)
Clavia Nord Modular G2 Engine.
Roland Alpha Juno1.
Yamaha QY70.
Want to sell/trade
Ensoniq ESQ1
Korg MS2000
Kurzweil K2000r V3
Yamaha TX802
gomidas
G2 patch files: 6
PostPosted: Sat Mar 17, 2007 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Hey! I see there's still a lot of thing I must learn about Nord Modulars.
Really, thank you, for ALL THIS TIPS.
GURUS RULES Wink
