Hello, I'm new here
Page 1 of 1 [15 Posts]
Digimaus
PostPosted: Sun Mar 11, 2007 4:30 am    Post subject: Hello, I'm new here
Subject description: Tuning and bootingproblem Andromeda
Helle everyone. I am a Andromedaowner since this week. A great synth but I'm having some problems with it. Actually 2 problems. Sad
Problem 1:
The Andromeda has problems with booting. From 10 times booting, 2 times it boots properly. The other 8 times the Andromeda does'nt boot.
Problem 2:
The Andromeda stays out of tune, even after the autotune function after warming up. I also proceeded a software-reset and a hardware-reset as well but unfortunately without result. It stays out of tune.
My Andromeda is not placed nearby any heatsource or something. The temperature in the room is conditioned and stable. So that cannot be the problem. I hope there is a solution for these problems.
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun Mar 11, 2007 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Digimaus
welcome to electro-music.com Very Happy
I hope someone can answer your questions but it looks like your Andromeda has to be replaced, the sooner the better.
mtvic
PostPosted: Sun Mar 11, 2007 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
egw has an Alesis Andromeda.
maybe he can help.
egw?
m
sunny pedaal
Audio files: 12
PostPosted: Mon Mar 12, 2007 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome,
seems , as you already performed a soft and hardwarereset, the problem seems even more hardwared. maybe the motherboard, however, as i also don't have the schema's or further specs of the a6 ( like nobody except neumark), it seems best to quickly make use of your guarantee and contact the nearby servicestation/ neumark or the dealer were you bought it. maybe start by sending a mail to neumark/ alesis.
keep us informed and good luck!
ten
PostPosted: Tue Mar 13, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I had similar problems with my 2nd Andro (the first none of the voices were in tune.)
My 2nd andy would only boot up every 4 times or so, and then voice 6 and 14 were ALWAYS out of tune. Digital Village in the UK let me keep it for 6 months until another one came in stock but I returned it today for a full refund as more of the voices were going bad.
I am going to forget buying one new and see if I can source a working one 2nd hand now, only after testing it fully first Smile
tom
sunny pedaal
Audio files: 12
PostPosted: Tue Mar 13, 2007 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
that's why i wrote first to contact the neumark/alesis servicestation or the website before contacting some dealer who doesn't know anything of the a6. direct contact with the service station i my experience spared a lot of time.
not a real pro for digital village i guess, presume you'll get the waiting time ( in writing) returned on your guarantee ?
ten
PostPosted: Tue Mar 13, 2007 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Digital Village are pretty good here in the UK, but I dont think many suppliers know about the problems with the new Andys. To be honest, Numark/Alesis should be thoroughly testing each one before letting them off of the of the production line, then we wouldnt be having this problem.
Maybe I will try for a synsun instead Smile
tom
sunny pedaal
Audio files: 12
PostPosted: Tue Mar 13, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
old or new , mine is an older type, had the same problem, seems repairing discovered mistakes is still cheaper then testing all beforehand .
the polyevolver+ expander would be nice too i guess
Digimaus
PostPosted: Thu Mar 15, 2007 3:24 pm    Post subject: Andromeda problem Reply with quote  Mark this post and the followings unread
Hi, thanx for all your reactions, great. I contacted Alesis and they said to me that Andy has to go back to the Alesis servicestation. If it's possible Andy will be repaired, otherwise I get a new one. We'll see. Andy has left the building. The only thing is now that I'm Andyless..... Sad Can anyone make minutes go faster...
Digimaus
PostPosted: Mon Jul 02, 2007 7:30 pm    Post subject:  Andy back in the building! Reply with quote  Mark this post and the followings unread
Finally, This week Andy returned to me after 3,5 month's servicecentre. It's working perfectly, just as it should be. What an awesome synth, a monster! I'm reborn, happy as a little child.
Digimaus
PostPosted: Sat Jul 14, 2007 5:48 am    Post subject: Chapter 2 Reply with quote  Mark this post and the followings unread
------ Chapter 2 - The next story ------
Andy was doiing well for 3 days. The next morning there was a short circuit in one of the IC's so everything got stucked. Andy went back again to the servicecentre and I'll get it back after repairing and a duration test. We shall see...
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jul 14, 2007 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
You're not really being lucky or anything Shocked
sunny pedaal
Audio files: 12
PostPosted: Sat Jul 14, 2007 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
well not on the subject of the andromeda, presume everything further is going well.
?what did they repair the first time?
Digimaus
PostPosted: Mon Jul 23, 2007 5:29 pm    Post subject:
Subject description: Andy back again!!
Andy is back for the 2nd time and is working well so far. They checked and repaired the following stuff:
- a shortcut in one of the IC's
- replacemant controller IC
- replacement right front PCB
- 2x switch ENV VIEW and DELAY
- duration test
I ordered a SRAM memorycard this week so I can finally start making awefull crazy sounds.
sunny pedaal
Audio files: 12
PostPosted: Tue Jul 24, 2007 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
congratualations!
i'm really curious of your "moody" sounds...
Niio1
