jeremy23
Posted: Sat Mar 17, 2007 2:28 am Post subject:
FACTORY RESET? Subject description: factory reset |
Hi there, just bought an andromeda, and it as the floor model, i wanna do a factory reset to make sure its exactly as it should be.
I looked in the manual but couldnt find the term "factory re set) Has anyone done this?
JeReMy |
invalidbuffalo
Posted: Sun Sep 30, 2007 7:19 pm Post subject:
| Hold down soft button 3 while powering on. That performs a hard reset. |
Peake
Joined: Jun 29, 2007 Posts: 1095 Location: Loss Angeles
Posted: Sun Sep 30, 2007 7:50 pm Post subject:
3 and 4 are different. I believe that 3 is a soft reset, and 4 is a hard reset (will remove Programs, tuning tables, MIDI settings, etc. so use with caution).
One or the other-- anyone? I've finally forgotten. The screen prompts should assist.
Note. After doing a hard reset, I believe the unit does an auto-tune. This auto-tune is critical. Allow it to finish. Tune again after a few minutes and your tuning tables should be set again. |
invalidbuffalo
Posted: Sun Sep 30, 2007 10:30 pm Post subject:
| It's 3, according to the user manual. |
Peake
Posted: Sun Sep 30, 2007 11:56 pm Post subject:
| Thanks, and I hope that everything is fine with your A6. |
amnesia
Posted: Mon Oct 01, 2007 2:03 am Post subject:
| I accidently initialised the User patches, Id love to be able to load them again. Can I and where can I dld ? |
sunny pedaal
Joined: Nov 16, 2004 Posts: 651 Location: netherlands
Audio files: 12
Posted: Mon Oct 01, 2007 10:46 am Post subject:
(copied from the manual ! recommended, read it twice, plus the tips + tricks, from beginning till end !)
POWER UP MODES
We have already mentioned a few power up modes that are entered by holding down a soft button while powering up the A6. Here is a summary of all of them:
POWER UP WHILE HOLDING FUNCTION
Soft Button 1 Forces A6 to load default Program and Mix. This is useful if the A6 has received corrupted data, causing it to hang.
Soft Button 2 Enters front panel debug mode.
Soft Button 3 Initializes all user RAM. This is also known as a Hard Reset. Warning, this will erase all User Programs and Mixes, replacing them with the factory default User Programs and Mixes!
Soft Button 4 Initializes all Global parameters, including tuning tables.
Soft Button 5 Re-calibrates Mod Wheel and Ribbon Controller.
Soft Button 6 Sends software OS out as MIDI Syx Ex dump.
Soft Button 7 Enables the A6 to receive software Syx Ex dump (OS or bootloader).
Soft Button 8 Replaces the factory default User Programs and Mixes with the User Bank Programs and Mixes. The next time a RAM initialization is done (Soft Button 3), these banks will be used to initialize the User Banks. Last edited by sunny pedaal on Mon Oct 01, 2007 10:50 am; edited 2 times in total |
sunny pedaal
Audio files: 12
Posted: Mon Oct 01, 2007 10:48 am Post subject:
so as i understand it's softbutton 3
fr.gr. sunny |
Peake
Posted: Mon Oct 01, 2007 10:54 pm Post subject:
Here is the Alesis page for the last official OS 1.4.12, the factory soundset, and some free soundsets from those who helped to test and voice the unit.
http://www.alesis.com/forums.html?id=58,36,0,0,1,0 |
