Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Wed Aug 06, 2008 1:10 am Post subject:
Btw: Mono, that SDS3 demo you posted sounds lovely! For some reason I can't play the second one, but the first one did the trick for me
Does anyone have a clear, top-down shot of the front panel of the SDS3?
Just to get an idea what's on there...
C _________________ Burn These Beats - drum loops | Prototype Graveyard - drum samples |
Joined: Apr 03, 2004 Posts: 19599 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Wed Aug 06, 2008 2:29 am Post subject:
A mil is a milli inch. _________________ Jan |
Coriolis
Posted: Wed Aug 06, 2008 2:31 am Post subject:
I see - thanks guys.
mono-poly
Joined: Jul 07, 2004 Posts: 931 Location: Rotterdam, Netherlands
asafnetzer
Posted: Wed Aug 06, 2008 6:19 am Post subject:
I think that pcb mount hardware can help and make a cleaner looking board and if some of us wants we could always add wires instead.
I'm not afraid of the overall size as I think this should be a standalone module, but maybe thats just me.  |
bubblechamber
Posted: Wed Aug 06, 2008 12:06 pm Post subject:
we won't be matching trannies on this...
i should get a lot more work done today... i'll post a preliminary panel layout
as soon as i get it done
PCB mounted hardware will make the layout a lot easier. with a little luck we'll have this wrapped up in the next month or so....
There will at least be a CV for the pitch control.
david _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
mono-poly
Posted: Wed Aug 06, 2008 3:23 pm Post subject:
On the orgional sds3 there were 3 drumchannels.
And one modulator channels with 2 lfo's if i remember right.
These could be routed to the pitch and the decay if i'm right. |
bubblechamber
stijn
Joined: Jul 21, 2008 Posts: 39 Location: utrecht, netherlands
Posted: Fri Aug 22, 2008 6:39 am Post subject:
oooh man, just discovered this thread. an sds3 clone lovely!
if there is going to be a pcb manufacturing run, I'm up for 4 at least  |
Luka
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Fri Aug 22, 2008 6:23 pm Post subject:
| I'd possibly be in for one as well. |
bubblechamber
Posted: Fri Aug 22, 2008 9:17 pm Post subject:
just about done with the layout...i'll start the double checking and testing next weekend.
if this works i'm thinking about doing a run of these. when it get closer to done i'll make a real announcement. looks like they'll cost around $8-10US each.
As Fonik predicted there is just not enough room for the pots to be PCB mounted if the PCB is to fit in a eurorack/frac faceplate and still be single sided for those that want to roll their own...
What I've decided to do is use a ribbon connector and a second board for the pots, jacks and switched. The header rows are around the edge of the board, so it should be pretty easy to wire up if you're putting it in something other than a Eurorack faceplate.
i'll keep you guy posted as this glacier slowly slide into the sea.
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Fri Aug 22, 2008 9:46 pm Post subject:
if you want to home etch this, you should make the traces much fatter.
in fact, i'd do that anywayz...
if you do a run, i will be in.
the mighty queue needs feeding, after all... |
Posted: Sat Aug 23, 2008 12:07 pm Post subject:
maybe this would be the right to time to make a decision: double sided professional PCB run or singlesided.
i'd preferred professional manufactured PCBs, no panel mount controls, circuit divided in voice and main boards, maybe just voiceboards...
what do you think? _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
bubblechamber
Posted: Sat Aug 23, 2008 11:27 pm Post subject:
| bugfight wrote: | if you want to home etch this, you should make the traces much fatter.
they'll be 3 or 4 times as thick for the Press N Peel version, it's just easier for me to work with thin traces in the layout phase...
| fonik wrote: | maybe this would be the right to time to make a decision: double sided professional PCB run or singlesided.
what do you think? |
I think the boards are going to be complete voices, no PCB mounted pots. i'll post a P'nP layout for a control board in a eurorack layout...
i've been thinking pretty seriously about doing a small run just for me and a couple of friends. I want at least 8 of these and I really don't want to etch and drill that many.
i'll do a broader announcement next week and see what kind of interest there is in this, right now there are 25-30 spoken for so we don't need that many to get a good price on these.
it shouldn't be more than $8US each for the PCB, i'd like to get it down lower. there's a pretty big price break at 100. i'd love to see some 8 voice SDS3...
I will probably use MyroPCB, I've ordered boards from them before and I've been very happy with their work. _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
filterstein
Joined: Mar 17, 2007 Posts: 41 Location: The Netherlands
Posted: Sun Aug 24, 2008 10:53 am Post subject:
Great, I can't wait  |
Statick
Posted: Tue Aug 26, 2008 6:37 am Post subject:
hi, i just registered here to post on this thread
i recently acquired an SDS 3. it really is quite awesome!
i'm only borrowing it however, but i am trying to convince the owner to part with it (wish me luck!). any idea what a fair price is for an SDS 3 and a single pair of pads ?
anyway, i would be very interested in some of these PCBs so add my name to the list. also if i can help in any way by virtue of having a real SDS 3 sitting right next to me, just let me know. |
SineSurfer
Posted: Tue Aug 26, 2008 11:29 am Post subject:
I may be interested in a couple of boards too.
Statick: do you think you could share some SDS 3 sound samples?, been searching the web for some without any luck
Thanks! |
mono-poly
Posted: Tue Aug 26, 2008 3:23 pm Post subject:
| SineSurfer wrote: | I may be interested in a couple of boards too.
Thanks! |
There are 2 examples from a sds3 in this tread somewhere. |
SineSurfer
Statick
Posted: Tue Aug 26, 2008 4:45 pm Post subject:
Thanks! |
sure, i'll record some stuff when i get some spare time (which i don't have a lot of at the moment). anything in particular or just a range of stuff ? |
Statick
Posted: Tue Aug 26, 2008 4:47 pm Post subject:
| SineSurfer wrote: |
So, each channel is capable of doing the whole range of sounds then(bd, snare, etc.)? |
yes, each channel is identical |
SineSurfer
Posted: Wed Aug 27, 2008 8:29 am Post subject:
| Statick wrote: | | ... anything in particular or just a range of stuff ? | Thanks Statick, the previous examples got me convinced already  |
Dego
Posted: Fri Oct 03, 2008 4:31 am Post subject:
How is this project developing? No hurry. Just thinking on it... |
