Simmons SDS 3 - DIY?
Page 13 of 14 [345 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14 Next
arnoid
PostPosted: Thu Jun 20, 2013 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice pcb Jmejia did you add the run generator ?
http://www.soundcloud.com/arnoid
http://www.facebook.com/arnoid
jmejia
PostPosted: Thu Jun 20, 2013 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet! Thanks - I'll give it a shot!
jmejia
PostPosted: Thu Jun 20, 2013 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh and arnoid - no we are leaving the run generator alone for the moment. Either none of us have gotten it to work right - or it's just not that interesting. It could always be an add-on pcb if someone wants to tackle it! I'm not personally that interested in it...
xpmtl
PostPosted: Sat Jun 29, 2013 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Populated that today.
Few things to iron out (noise is not working)... And i'll need to make another prototype as i wired the decay pot backwards again Rolling Eyes
More debugging to come Laughing
EDIT : Fixed the noise problem, apparently BC547 doesn't work for the noise circuit here, it does on my thru-hole prototype. Very odd.
I've replace it with a 2N3904 and it works. (Tim i'll send you those in replacement)
 Filesize:  895.92 KB
 Viewed:  397 Time(s)
 Filesize:  743.5 KB
 Viewed:  368 Time(s)
http://sdiy.xpmtl.net
jmejia
PostPosted: Sat Jun 29, 2013 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great xpmtl!
Just sent our prototype gerbers to the fab yesterday. Will update once we get a few boards back!
nuipb
PostPosted: Sat Jun 29, 2013 2:30 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Looks really incredible !
congratulations !!
THeff
PostPosted: Sun Jun 30, 2013 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice clean layout xpmtl!
Four of those PCBs side by side would make a great SDS-3 package.
Great work!
Regards,
-Theff
xpmtl
PostPosted: Mon Jul 01, 2013 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thankies !
That was my initial plan Smile (I got 5 pcbs from iTead)
If only I didn't screwed up with the decay pot it would have been perfect Embarassed
Having the shortest decay on CW is a bit odd but i think i'll live with that. I'll just correct this issue for the gerbers i'll share.
I'll send the front panel design to engraving this week so i can test if it fits.
x.
Heavy Metal Kid
PostPosted: Mon Jul 01, 2013 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks good!
nuipb
PostPosted: Mon Jul 01, 2013 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember reading this info in the thread but what is format you are planning to be build it for ? Stand alone ? Doepfer ? SDS-V ? other ?...
xpmtl
PostPosted: Sat Jul 06, 2013 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I think jmejia is doing an universal board that will work for all formats, an I think he will sell those.
Mine is 1U MOTM format, but i won't sell them. All the info and gerbers files are free to download on my site (sdiy.xpmtl.net). You'll have to send the gerbers to a fab house and source/populate the boards yourself.
x.
diablojoy
PostPosted: Sun Jul 07, 2013 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice layout xpmtl
MOTM format should work well for me
great work.
ask where the hell am I
as good an answer as any
nuipb
PostPosted: Sun Jul 07, 2013 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks. Hopefully I find someone with the knowledge to build one for me. I can barely resolder a bad cable...
What are the different voltages required from the power supply ?
arnoid
PostPosted: Mon Jul 08, 2013 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
x.
Is it possible to make a sound demo of your version ? Smile
xpmtl
PostPosted: Mon Jul 08, 2013 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
+/-15VDC
xpmtl
PostPosted: Mon Jul 08, 2013 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
As soon as i got the frontpanel done, i'll try to make one.
nuipb
PostPosted: Mon Jul 08, 2013 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
xpmtl wrote:
+/-15VDC
Then I guess it cannot be installed in a Doepfer system right ? They supply at most 12v as far as I know...
jmejia
PostPosted: Mon Jul 08, 2013 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
We should get our protos soon and are planning on testing with +/-12 in addition to +/-15 to see if it works - but nuipb, it sounds like 12 is working fine per xpmtl.
We have a euro connector on the board, as well as an MOTM connector, but no pcb-mount components, and no real consideration to mounting or pcb size apart from some arbitrary mounting screw holes in the corner. So it'll be DIY in terms of getting it to fit in whatever your system is.
We'll sell pcbs, but we'll also make our layout available.
nuipb
PostPosted: Wed Jul 10, 2013 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks. Looking forward to hear about your further tests then...
jmejia
PostPosted: Sat Jul 13, 2013 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
xpmtl
PostPosted: Sun Jul 14, 2013 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
nice board!
what size is it? looks small
jmejia
PostPosted: Mon Jul 15, 2013 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It's 102.57x83.82 mm (about 4" by 3.30")
Waiting on some parts still to populate and test.
jmejia
PostPosted: Wed Aug 07, 2013 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Small update here. Our prototype has some issues and is not oscillating. Noise, envelope, trigger and lfo circuits seem to be working.. although the grounding pots don't seem to remove either the noise nor the lfo.
We recycled the ca3046s and the jfets from our first rev.. so first order of troubleshooting is ordering fresh parts and trying them out. More on that front soon...
xpmtl
PostPosted: Thu Aug 08, 2013 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
You can check if the 3046 are ok using the voltages Tim has posted on page 10, If you have them right then it's probably the Fets. From memory you should get 10.80V, 7.8V and 15V on the Fets legs.
X
mono-poly
PostPosted: Wed Aug 14, 2013 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
x.
Woow great work!
Looking forward to your gerber files!
