goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Tue Jun 19, 2007 9:34 pm Post subject:
Thanks for the kind words everyone, here's a pic of the just finished, smaller I/O board. Beware, there seem to be some labelling errors on the component layout for this one. I'll post P&P layouts and porject notes if and when I get it operational.
-justin |
goodrevdoc
Posted: Tue Jul 17, 2007 12:14 pm Post subject:
SUCCESS!!!
After frying a couple of op-amps, and one slightly more expensive compander, this thing is now vocoding like the dickens!
I'll try to post some samples later, and will definately fix my layout errors and post some PDF's of the project info. I just can't beleive it, this is by far my new favorite toy, and I didn't even have to learn Japanese to make it.(which I briefly considered doing, deep in the throes of debugging) Out the door now, but like I said, I'll try to get some sounds up later...
-justin |
Wild Zebra
Posted: Tue Jul 17, 2007 12:32 pm Post subject:
Congrats, looking forward to some samples and documentation. _________________ "your stripes are killer bro" |
psylux
Posted: Tue Jul 17, 2007 1:33 pm Post subject:
| very interested, can't wait for the details! |
crashlander42
Joined: Oct 21, 2006 Posts: 272 Location: Orlando, FL (US)
goodrevdoc
Posted: Tue Jul 17, 2007 6:11 pm Post subject:
OK, as promised, here's a quick & dirty sample. It was recorded on my cellphone. Believe it or not, that's the easiest & best way for me to record right now, other than reel-to-reel. It was done with my trusty Moog MG-1 as the instrument source with a sawtooth and not much filtering. Microphone is an SM57. Amp was a crappy little practice amp I keep under my bench for just such occasions. It sounds much better than this, but this sample does it pretty adequate justice. As for the project file, It should be finalized in the next week or so, but right now one of the op-amps is still running pretty hot, so I want to get that nailed down before I do anything else. Also, thanks for the kind words everyone, its nice to have some support when attempting the largely futile. OK, enough blabbering, to the sample already!
-justin
| Hello electro-music.com... This is my new Okita vocoder... |
 Download |
| Filename: |
Vocoder.wav |
15.74 KB |
| Downloaded: |
1107 Time(s) |
crashlander42
goodrevdoc
Posted: Tue Jul 17, 2007 6:55 pm Post subject:
The CAG pdf file is not to scale, nor is the one over at colin's site. Also they are bottom views. (not oriented for P&P) I took the CAG files, imported them into Osmond Quartz, and painstakingly re-did them many moons ago. The smaller boards also had a few small errors in them, so they were fixed along the way. In addition, once assembled, I found a few additional errors that I had made, so I would like to incorporate them into the file before I release them. Then too, there is the hot Op-Amp. But if you want to start getting ready, the board sizes are a whopping 8"x6" and 5"x4", the former being the biggest thing I've ever P&P'd or etched, easily.
-justin |
crashlander42
goodrevdoc
Posted: Tue Jul 17, 2007 11:11 pm Post subject:
I had the same problem...
-justin |
goodrevdoc
crashlander42
Etaoin
Joined: Jun 30, 2005 Posts: 760 Location: Utrecht, NL
Posted: Tue Nov 06, 2007 11:21 pm Post subject:
Great stuff. I was actually looking into building the Elektor vocoder, but this is a lot less work  _________________ http://www.casia.org/modular/ |
bubblechamber
Posted: Tue Nov 06, 2007 11:23 pm Post subject:
| really nice work. looks like I'll be building a vocoder or 2 this winter. great job. |
23isgood
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Tue Nov 06, 2007 11:51 pm Post subject:
Very nice job! I absolutely love vocoder's. My favorite is the Roland VP330. Could you post a sample please? I could not find the previous sample you put up. Also where could I find the schematics.
thanks,
pete _________________ Check out my music |
Etaoin
goodrevdoc
Posted: Wed Nov 07, 2007 12:42 am Post subject:
Thanks for putting up those links, Etaoin. Also, the link to the original scanned article is at the beginning of this thread. I just put the sample back up as well. I may try the Elektor next, but I believe there are some weird parts to be had with that one...
-justin |
Etaoin
Posted: Wed Nov 07, 2007 12:44 am Post subject:
I'll have a quick check for the Elektor one, but I think the weirdest part in there is the 3080 (which isn't that weird). Only problem I had were the terrible PCB scans. _________________ http://www.casia.org/modular/ |
Etaoin
Posted: Wed Nov 07, 2007 12:50 am Post subject:
Okay, also TDA1034. One could probably use the NE5534 there. _________________ http://www.casia.org/modular/ |
goodrevdoc
Posted: Wed Nov 07, 2007 10:04 am Post subject:
I was thinking about those 21 pin Siemens connectors. I searched for some awhile ago with no luck, but not very hard. The 3080 is no problem and the TDA1034 should only be a minor bump...
-justin |
23isgood
Posted: Wed Nov 07, 2007 4:02 pm Post subject:
Sounds cool! I can imagen all the different type of sounds you could get by patching in different synths. I would love to hear some more samples. I really want to build this, but with the Klee I will be pretty busy for a minute. A future project for sure.
thanks
Etaoin
Posted: Thu Nov 08, 2007 12:35 am Post subject:
| Quote: | | I was thinking about those 21 pin Siemens connectors. I searched for some awhile ago with no luck, but not very hard. |
Yes, European connectors... easier to get over here. _________________ http://www.casia.org/modular/ |
TheProf
Joined: Dec 26, 2006 Posts: 133 Location: United Kingdom
Posted: Thu Nov 08, 2007 5:58 am Post subject:
I still have the original elektor articles, I think. I did wonder about a batch of boards, being as there are several of the main filter boards. I think revising the layouts might be a good idea, in order to have options for different capacitors, as Jurgen did on his excellently thought out Tau pipe boards, (I really hate it when you have to faff around finding the caps in the right pin spacing as well as value, and it is more difficult to experiment).
I built two of these, for friends, back in the day, using Elektor's own boards. They worked well, though I have heard better. The ability to patch out the filter is a definite plus.
The other one I built was the ETI design, done by Tim Orr, of EMS. That was a good design, but needed a huge main board, about 16x6 or something, which id definitely not practical unless your name is Jim Patchell, (that guy's boards are awesome!). This sounded a bit nicer than the elektor, but wasn't patchable, it might also be that by then I was into using a sweep gen and display, had a capacitance bridge, and hand tuned the filters, the Elektors were just done 'straight out of the box', and in a hurry, for an experimental vocal group, (they thought their grant would cover a couple of EMS's, and when it didn't, were under time pressure for a performance). I wonder what happened to them -
I did think of doing a re-work of the ETI, beginning with stripboard in a rackframe like the Elektor, and allowing patching.
This thread has reminded me to take a look.
I may be some time....... _________________ Mike |
goodrevdoc
Posted: Thu Nov 08, 2007 12:34 pm Post subject:
| Quote: | | Yes, European connectors... easier to get over here. |
I see. If I ever actually have a go at it, I may have to hit someone up on that side of the pond then.
| Quote: | I built two of these, for friends, back in the day, using Elektor's own boards. They worked well, though I have heard better. The ability to patch out the filter is a definite plus.
The other one I built was the ETI design, done by Tim Orr, of EMS. |
I have the files from CAG for both of these, but after thinking it over for awhile, the elektor is probably the way to go. An 8X6 board was hard enough to PnP and etch, 16X6 is surely a nightmare!!! (although totally possible)
-justin |
Etaoin
Posted: Thu Nov 08, 2007 12:43 pm Post subject:
| Quote: |
At least I think these ones sold by Conrad are the right ones (pictures are 13 pins, they also sell 21 pins)
8.68 KB |
| Viewed: |
12184 Time(s) |
6.53 KB |
| Viewed: |
12184 Time(s) |
