SeqCtr Bug
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Tue Mar 27, 2007 2:44 pm    Post subject: SeqCtr Bug
Subject description: 16th value wrong
Found an interesting bug in the seqctr module. In a polyphonic patch, if the last step is selected, the Clr and Rnd buttons change value for all but one voice. This 4 voice patch uses step 16 to detune the oscillator. Move the 16 slider and the pitch changes, now press Clr to reset to zero and press a key repeatedly. You will notice one voice still detuned as you cycle through. Move the slider to zero manually and all voices go back into tune. The random button has a similar problem.
SeqCtrBug.pch2
bug in seqctr
 Filename:  SeqCtrBug.pch2
 Filesize:  1.28 KB
 Downloaded:  923 Time(s)
