<on air> Muied Lumens Frequencies
MIDI and Timing issues
Page 1 of 1 [7 Posts]
momo_the_monster
PostPosted: Thu Apr 12, 2007 11:09 pm    Post subject: MIDI and Timing issues Reply with quote  Mark this post and the followings unread
So I'm beginning work on my AV game - think of it like Parappa the Rapper with Audio/Visual clips.
The first thing I need to get working is that I need to detect whether the user inputs MIDI notes at the proper time (and allow a variable tolerance). So I figured I would start by toggling back and forth between binary states in a variable along with an audible sound, and seeing if I could detect whether or not an input was received during the '1' input, ignoring the opposite.
This is the code I've got so far:
Code:
MidiIn min;
MidiMsg msg;
MidiOut mout;
   if(!min.open(0)) me.exit();
int i;
// connect sine oscillator to D/A convertor (sound card)
      SinOsc s => dac;
while (true) {
300 => s.freq;
1 => i;
<<<i>>>;
if( min.recv( msg )&& msg.data3 != 0 && i==1 )
{ <<<msg>>>;}
1::second => now;
0 => s.freq;
0 => i;
<<<i>>>;
   1::second => now;
It doesn't really work right. If I push a MIDI note, it always gets sent, with a delay if it's pushed during the '0'. If I push it a couple of times, it gets queued up and comes through during the next few times. Any tips?
VJ Kung Fu :: Online Motion Magazine for DIY Video Artists
Last edited by momo_the_monster on Fri Apr 13, 2007 9:13 am; edited 1 time in total
moudi
PostPosted: Fri Apr 13, 2007 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
hi momo
there is a special code tag when you need to post code.
otherwise some special characters get lost.
look also at this thread: http://electro-music.com/forum/topic-14150.html
i think that this is the case with characters like them in your code:
(even i have to admit, that i didn't tried to run it already).
besides of this, welcome to ChucK Cool
jassas
/moudi
spencer
PostPosted: Mon Apr 16, 2007 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi momo,
I think this doesn't work because MidiIn buffers MIDI messages. You probably need to read every MIDI message that is sent, and then decide if it happened at the right time. For this you'll need two shreds, one to keep track of the "right time" and one to handle MIDI input. Does the following code work a little better? (warning: I haven't tested it.)
Code:
MidiIn min;
MidiMsg msg;
MidiOut mout;
int i;
SinOsc s => dac;
fun void doMIDI()
    while (true)
        min => now;
        while( min.recv( msg ) && msg.data3 != 0 )
            if( i == 1 )
                <<<msg>>>;
spork ~ doMIDI();
while( true )
    300 => s.freq;
    1 => i;
    <<<i>>>;
    1::second => now;
    0 => s.freq;
    0 => i;
    <<<i>>>;
    1::second => now;
spencer
momo_the_monster
PostPosted: Mon Apr 16, 2007 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes yes! The problem was exactly that - the MIDI messages were getting queued up, but I tried all sorts of looping and control structures to no avail. Your solution worked excellently - and I'm now on my way. Thanks!
renderful
PostPosted: Wed Apr 18, 2007 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
This helped me greatly!
Thanks Spencer.
PostPosted: Wed Apr 18, 2007 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome on board, Renderful!
renderful
PostPosted: Wed Apr 18, 2007 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kassen. Currently playing with SMELT, noticed it in your Updates! thread. Great little toolset, already created an additive synth which uses touchpad coordinates to control frequency of each OSC.
Happy to be here. I've already learned so much!
