today> Twyndyllyngs Live - special shelter in place episode with Ninjam Chez Mosc
Alternative drawbar (for hammond)
Falk
G2 patch files: 29
PostPosted: Sun Apr 22, 2007 2:21 am    Post subject: Alternative drawbar (for hammond) Reply with quote  Mark this post and the followings unread
Hello.
I was admiring Chets Hammond patch http://electro-music.com/forum/viewtopic.php?highlight=drawbars&t=11319 and was trying to bring it down to below 50% in memory to get some more polyphony out of it. Turns out to be hard.
One of the villains in this drama are the Sw8-1 modules used as drawbars (lots of inputs and outputs means a high memory usage). I tried to patch something that didn't use as much memory and came up with this.
Pros: Less memory usage, can change number of steps.
Cons: Uses more CPU, doesn't have that nice stepped visual feedback on the knobs, no global volume attenuation to all drawbars.
Conclusion: If you got more CPU to spare then memory, you might consider this drawbar.
Picture of drawbar
 Filesize:  21.55 KB
 Viewed:  2690 Time(s)
