doctorvague
Posted: Tue Apr 24, 2007 3:18 pm Post subject:
Fairchild H11F1 Optocoupler - sound samples added |
Ran across this today:
http://www.fairchildsemi.com/ds/H1/H11F1.pdf
It appears this would work more or less, in place of a vactrol, yes-no?
With a turn-on time of 25uS. Hmmm. Not that I don't love the lazy 'thwip' of a vactrol...
Unless someone talks me out of it I'm ordering some of these and some Silonex "Vactrols" this week to blow u...I mean experiment with as alternatives to the VTL5C's.
Your thoughts?
Phil
We have knobs so we must twist them. Last edited by doctorvague on Fri May 11, 2007 9:27 am; edited 1 time in total |
sohcahtoa
Posted: Tue Apr 24, 2007 7:45 pm Post subject:
vactrol if I am not mistaken vary resistance, this is a circuit varies a transistor.
but after looking at the data sheet
As a remote variable resistor
•≤ 100 Ω to ≥ 300 M Ω with ≥ 99.9%
linearity which is exactly what you want.
Edit:
•greater than 100 ohms to less than 300 M ohms with greater than 99.9%
funny I can write the ohm symbol in the editor but it does not post to the forum |
bugbrand
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Wed Apr 25, 2007 12:57 pm Post subject:
what would the advantage be ?
Price or performance or availability ? _________________ Stay Cool
Mikael
http://www.mikmo.dk |
doctorvague
Posted: Wed Apr 25, 2007 2:16 pm Post subject:
Thanks for the replies. I'm ordering some today and will report. They are somewhat more expensive than Vactrols, but they are way faster and appear to have a more linear curve, but we'll see how they do musically, etc. I'm a 'hook it up and see what happens' kind of DIY guy so if you want the algebra someone else will have to buy a couple and chime in. The example circuits are dead simple so that's a good sign
clippin' alligators
Phil |
doctorvague
Posted: Thu May 10, 2007 2:56 pm Post subject:
Hi all
My observations are that the H11F1 is largely interchangeable with the VTL's but as you would expect the transfer curve is different, which can be compensated for of course.
I've got a filter design which is nearly completed and have decided to use 3 different "vactrols" i.e. optocouplers including the H11F1, actually one of the the other opto's switches out with the H11F1 using a DPDT. In this filter design this chip has a buzzy quality and breaks up in a way that is very pleasing to my ear. If used moderately it can be pretty breathy- or actually 'woodwindy'.
This example uses 1 triangle wave and 1 square wave into the filter in 'buzz mode' (using the H11F1). It will overdrive more than this with more input, but this shows off some subtleties. Recorded dry, no VCA, straight into the mixer. Because of the magic of vactrols in many patches you don't need a VCA with this filter. The filter has a really short signal path and a pretty strange passive resonance circuit but doesn't resonate into oscillation. More later.
http://idisk.mac.com/doctorvague/Public/Clips/RF-1buzz1tri1square.mp3
Clippin' alligators,
Phil |
doctorvague
Scott Stites
Audio files: 96
Posted: Fri May 11, 2007 10:47 am Post subject:
Herr Doktor -
I really like these samples. The woodwind sounding one is particularly interesting.
I was also able to hear some of the other jam files you turned me onto (am listening now). Simply marvelous! - have you posted anything like that in the music section here yet (I don't get there as much as I should)?
Scott |
doctorvague
Posted: Mon May 14, 2007 6:06 am Post subject:
Just a second, Scott.... sorry I thought I heard a pin drop in the balcony. |
mediatechnology
Joined: May 10, 2006 Posts: 80 Location: Oak Cliff, Texas USA
Posted: Sat May 19, 2007 7:12 pm Post subject:
I've used the H11F1 in a few experiments and it's a very interesting part. Compared to a JFET it has the unique property of not having control feed-through. In a shunt configuration as a voltage-controlled-resistor it's limited to 50-100 mV or so due to distortion.
I did some nose gate experiments and it was very, very fast and makes a great switch. |
doctorvague
Posted: Sun May 20, 2007 4:07 am Post subject:
mediatechnology wrote: | I've used the H11F1 in a few experiments and it's a very interesting part. Compared to a JFET it has the unique property of not having control feed-through. In a shunt configuration as a voltage-controlled-resistor it's limited to 50-100 mV or so due to distortion.
Sometimes you need a good nose gate.
mediatechnology
Posted: Sun May 20, 2007 8:26 am Post subject:
For control linearization, constant-current LED drive might be worth trying.
Another idea I had was to use the LED as a diode in a peak detector. The FET would then respond to charging current above the value stored on the hold capacitor. I don't know what practical use that might have, perhaps a means of detecting crest-factor, but it's fun to think about and maybe try in a peak-limiting application.
As the datasheet points out, used as a sample and hold it will have low charge injection. In an industrial application having the S/H control galvanically isolated is very useful.
Just thought of another one: Use the FETs as switches to form precision rectifiers. Use a single op amp polarity flipper with a single FET switching polarity. Drive the LED from a comparator-based zero crossing detector. Hmm...Think I want to try that one.
Modulator applications?
I've always thought that this simple part (the H11F1) has some amazing possibilities.
Has anyone done a multi-pole phaser with it? |
Noiseconformist
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Wed Aug 06, 2008 4:16 am Post subject:
This sounds pretty nice (ok late reply) |
mediatechnology
Posted: Wed Aug 06, 2008 4:23 am Post subject:
Thanks for the new link to the H11F datasheet.
I had read (Digi-Key IIRC) that this part was going end-of-life and had last time buy status. The new datasheet, dated 2007, doesn't mention this and I hope that it has been kept in the Fairchild line. It's starting to look that way. |
Noiseconformist
Posted: Wed Aug 06, 2008 5:04 am Post subject:
you're welcome! (at least reason enough to end my lurking existence ) _________________ hear the colours of noise |
Noiseconformist
Posted: Wed Aug 06, 2008 3:37 pm Post subject:
useful for "transparent" replacement of Rs? |
mediatechnology wrote: | The new datasheet, dated 2007, doesn't mention this and I hope that it has been kept in the Fairchild line. It's starting to look that way. |
Since you mentioned they are fast, is the H11F1 useful for things like VC-resonance etc. if I wanted to maintain the original design's sound?
(which I would think they are)
Michael. _________________ hear the colours of noise |
mediatechnology
Posted: Wed Aug 06, 2008 3:56 pm Post subject:
I haven't used them in any filter topologies yet. That interests me particularly multi-pole phasers.
I tried them in a gate application, signal selector and voltage-controlled shunt attenuator.
As mentioned earlier by another poster the signal level (I tried it in shunt as a VCR) is limited to a pretty low level around 50 - 100 mV. THD rises rapidly after that.
The signal selector and gate used them in the virtual ground node of an op amp so the p-p voltage wasn't an issue. |
doctorvague
Posted: Thu Aug 07, 2008 4:31 pm Post subject:
Just for the record my examples above were all in the context of using it in an offshoot switchable souped up version of Scott Stite's Mutant vactrol filter... actually it was more from the original Buchla as I recall. Anyway I never thought to try the H11F1 in the CV side of the circuit.
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id17.html
I was overdriving the crap out of it in those examples. Will that blow them up eventually or just create high THD like a guitar amp?
Here's another one you can really hear it crying for mercy a bit (450K):
http://idisk.mac.com/doctorvague/Public/Clips/tof-1buzz1.mp3
If this works for CV resonance I'd like to hear about that.
cheers
Phil _________________ doctorvague's youtube channel Last edited by doctorvague on Thu Aug 07, 2008 6:06 pm; edited 1 time in total |
mediatechnology
Posted: Thu Aug 07, 2008 5:38 pm Post subject:
Quote: | I was overdriving the crap out of it in those examples. Will that blow them up eventually or just create high THD like a guitar amp? |
My experience was that it just distorts. I can't remember if it was dominate even or odd. |
doctorvague
Posted: Fri Aug 08, 2008 4:39 am Post subject:
mediatechnology wrote: | Quote: | I was overdriving the crap out of it in those examples. Will that blow them up eventually or just create high THD like a guitar amp? |
I didn't mean any particular quality to the distortion - I'm just asking can you run it like that for extended peiods of time unharmed (like a guitar amp), or is it eventually going to go up in smoke from overheating, etc? _________________ doctorvague's youtube channel |
mediatechnology
Posted: Fri Aug 08, 2008 6:10 am Post subject:
The short answer to your question is: "it will just distort."
With regard to damaging the H11FM here's the long answer:
The FET continuous current absolute maximum is +/-100 mA. The LED continuous forward current absolute maximum is 60 mA.
>+/-100mA signal (FET) current or >60mA LED current would harm the device. It's doubtful that in most effects applications you could get that kind of signal current to develop during severe overdrive for the FET. In most applications the LED will be resistively current limited far below 60 mA.
In severe FET overdrive, at least in a shunt or variable R topology, the main thing you'll get is distortion - at least in carefully-designed circuits. |
doctorvague
Posted: Fri Aug 08, 2008 6:26 am Post subject:
mediatechnology wrote: | The short answer to your question is: "it will just distort."
Thanks for that. In my case was running full signal oscillators through a similar circuit to a LPG using the H11F1 in place of the usual VTL5C3/2, overdriving the FET side, not the LED. It never blew up through hours of use but seems like maybe it should have! _________________ doctorvague's youtube channel |
intellijel
Joined: Sep 10, 2006 Posts: 67 Location: Vancouver, BC
Posted: Mon Sep 13, 2010 11:19 am Post subject:
I am trying to drive the led of an H11F1M opto isolator .
The problem is that it seems to only have a range of 60-400 ohms and then suddenly jumps to infinite resitance. The data sheet seems to be missing very important information yet it claims a linear response over a huge range (without graphs to back this up mind you).
I have tried driving the led with transistor circuits and as part of the feedback path in an opamp.
I see some people here have used these succefully. Do you guys have any tips? Any schematics to share?
Ideally I would like to get a resistance in the range of 60ohms to 50k |
Joined: Nov 23, 2015 Posts: 1294 Location: Netherlands
