mao
Posted: Sat Apr 28, 2007 6:41 am Post subject:
GUIDE: HOW TO USE YOUR A6 TO CONTROL VST using CUBASE SX3 Subject description: a step by step guide... on how to... |
Here is how to control a vst using the Andromeda as a controller and Cubase SX3:
This is for Cubase SX3 user, I don’t know if it’s working on previous version.
All the things you need to do is to create a generic remote controller, where NRPN andromeda controllers are routed to the vst. This is a step by step guide... it seems a hell... I writed down everything ... it’s all a question of seconds and it’s easy.
Please remember i’m using an Italian CubaseSX 3 I hope my translation of the commands are right. If you can correct this guide... well do it for all the A6 users.
Let’s start... open cubase, start a new project and load a vst you want to control, let’s say for example the MS20 from korg legacy collection.
Now in cubase go in Devices --> Device setup (I hope this is the right name I’m using the Italian version!) and create a new remote controller.
A windows pop up withe the generic remote controller. You can see two tables. The first is where you create and map the andromeda controller (the source) and the second tables is where you choose what the knob has to control (the parameter on the vst).
First of all, see the combo box on down to the right... use the delete to delete every template... and add a new template and rename it MS20. With this combo box you can create a new template for every vst you want to map and then switch from a template to the other with a click using the A6 to control all your vst..
With the new template let’s start mapping the Andromeda. Go to the first column (name) of the upper table and type CUTOFF1.
Second column (midi) choose Ctrl-NRPN
Third column (channel) choose 1
Address column. .. here do this… WHILE MOVING the CUTOFF1 knob of the andromeda click LEARN button on CUBASE SX (the last button on the upper right) you will se a number (2432) that’s the Cutoff1 knob address.
Max Value column: 4000
Flags column: R,T
Ok now go to the bottom table and now we map the CUTOFF1 command we just created to the MS20 LPF CUTOFF
Name column: choose CUTOFF1 from the drop down menu... yes it’s what you created.
Device column: choose MS20 from the drop down menu
Channel column: choose DEVICE
Value/action: from the drop down meno of all the MS20 parameter choose LPF CUTOFF
Flags:,, (nothing)
Well you just mapped the A6 CUTOFF1 to the MS20 LPF CUTOFF.... BUT BEFORE USING IT FOLLOW ME please... we can continue with all the knobs and creating a new template for the PRO53 and so on but I think you want to try if it works !!! so do this:
EXPORT to xml using the EXPORT BUTTON ON THE RIGHT (the second) of the remote controller panel (next to the upper table...)
Name the file A6.xml (welll it’s just a name...) but put it into a safe folder and not move the file later.
NOW THE TRICKS... Cubase SX 3 has a little bug creating the xml file with mappings... sometimes it fails on writing the flag so... do this:
Close cubase...
Open the A6.xml file you created.
You will find something like:
<ctrl><name>CUTOFF1</name><stat>2</stat><chan>0</chan><addr>2432</addr><max>4000</max><flags>19</flags></ctrl>
BE SURE THE 19 on the FLAGS tag is there !!! if you see a 3 change it to 19 !!! that’s the bug !
Now save...
Now lets create a new model (template) for cubase... just to avoid to load the xml every time...
OPEN CUBASE start a new project and go again to Devices --> Device setup
Choose the remote controller you created... and use the IMPORT button to load your (fixed) A6.xml file
Choose APPLY and OK...
SAVE THE PROJECT AS A MODEL(template). Close the project and start a new project using the template you just saved...
This project will loads the xml so everything you need to do now is:
Load the vst (MS20), choose in cubase Window --> generic remote controller... a new little combo box will be added to your project. You will see a MS20 label on it... but if you have created another template for a PRO53 you will choose what to control using it.
be sure that palying the Andromeda the MS20 is playing... and move the andromeda CUTOFF1... if all is ok you will see the MS20 LPF moving !!!
well seems a lot of things but now... if you want to add all the knobs... you have not to do all from the beggining... simply open the remote controller window and add the knob and export the xml... (and check for the 19 to be everywhere.) It’s done... if the new knobs doesn’t work try closing the little combo box (window --> generic remote) and open it again... it simply needs a refresh.
Remember you can add several template for all your vst using the same xml file... you will choose the template to use in the little combo box (window --> generic remote) |
