  Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
 Forum index » Instruments and Equipment » Sequencers
Numerology help
Page 1 of 1 [5 Posts]
astedra
PostPosted: Sat May 12, 2007 12:50 pm    Post subject: Numerology help
Subject description: Can't start it
I can't start numerology I have a mac g3, 900 mghz with 640 ram, with Os 10.3. I have all the minimum system requiremnts. But it doesn't load.
Thanks,
Andrew
EdisonRex
Audio files: 168
PostPosted: Sun May 13, 2007 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
any particular error messages?
If you go into Activity Monitor, do you see the process running?
Activity Monitor is in applications/utilities
If you look in that utilities folder there is also a "console" utility. You could try running this utility when you try to start Numerology and see if any error messages pop up.
Garret: It's so retro.
astedra
PostPosted: Sun May 13, 2007 9:07 pm    Post subject: Numerology help
Subject description: help
It opens up for one second and in the quick lunch bar it shows up for one second and than it dissapears like it never happened.
No error messages at all.
EdisonRex
Audio files: 168
PostPosted: Mon May 14, 2007 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Five12 wrote:
Numerology requires Mac OS X, version 10.3.9 or later. Hardware requirements vary based on the number of modules you plan to use and whether or not you use Audio Units. Any system with a PPC G4 chip at 1Ghz or better is recommended, but if you only work with MIDI than a G3 500Mhz may be sufficient. Numerology 1.4.3 will work on an Intel Mac under Rosetta, but is not supported for AudioUnit hosting in that configuration.
Another question, are you trying to run in demo mode?
astedra
PostPosted: Mon May 14, 2007 7:48 am    Post subject: demo numerology
Subject description: demo
yes
mps board
