 Forum index » Instruments and Equipment » Sequencers
open logic express files on logic pro
Page 1 of 1 [9 Posts]
Zubben
PostPosted: Wed May 16, 2007 12:08 pm    Post subject: open logic express files on logic pro Reply with quote  Mark this post and the followings unread
Hello,
I would like to know if there is a way to open logic express projects on logic pro.
thank you
PostPosted: Wed May 16, 2007 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Confused
'open file' ?
Does Apple not want you to upgrade?
ACHTUNG!
EdisonRex
Audio files: 168
PostPosted: Wed May 16, 2007 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a trick question, right?
Logic Pro opens all of the "lower" versions of Apple's range of software. Since you have at the low end, Garageband, which is openable in Logic Express, which is simply a feature starved version of Pro, you can open Logic Express files in Logic Pro just by opening them. You can open Garageband files in Logic Pro, according to Apple. I've not used it, but this is consistent with Final Cut, which I do own and use. Final Cut has the same kind of grading of product functions. The files are totally upward compatible.
Garret: It's so retro.
Zubben
PostPosted: Wed May 16, 2007 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry my prob was different, it is juse because the logic pro I tried to use to open my files is logic pro 6, and my logic express is 7.2.
I heard they are not compatible, that's why it doesn't work...
Thank you
PostPosted: Thu May 17, 2007 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Well that's odd because I've opened all my Logic files made on Pro 6 (PPC) in Express 7.2 (Intel) I have exactly the same configuration, and have no problem (apart from a few missing plug-ins) Confused
Is there anything else you may have done wrong?
edit- are you saying Express 7.2 to Pro 6? The definately wouldn't work. 6 to 7.2 yes.
ACHTUNG!
PostPosted: Thu May 17, 2007 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Right, Garageband->Logic Express 7.latest->Logic Pro 7.latest works great. LP7 or LPX7 to L6 won´t work.
Flickr
seraph
Editor
Editor
Audio files: 31
PostPosted: Thu May 17, 2007 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
upward compatibility yes
downward compatibilty no
it's as simple as that
that's my haiku of the day
Cool
PostPosted: Thu May 17, 2007 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. can the same be applied to democracy? Shocked
Flickr
seraph
Editor
Editor
Audio files: 31
PostPosted: Thu May 17, 2007 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I ran out of haikus on this matter a long time ago Sad
